4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
stock 2.3 issue
Old 02-08-2015, 01:32 PM
C.Huskey
C.Huskey's Avatar
Default stock 2.3 issue
I am having issues with my 2.3. I took it to a reputable mechanic after a month or 2 of checking and looking over my self and he said he couldn't find the problem and I would have to take it to a dealer. The car starts and runs great until it warms up. then my idle , cant seem to hold a specific rpm. When driving after warmed up it has no low end power at all., push the accelerator down more and she opens up with lots of power. (for a stock 4 clyn.) Basically once its warmed up I cant drive it normal I have to drive it like I stole it.
C.Huskey is offline
Old 02-08-2015, 01:33 PM
C.Huskey
C.Huskey's Avatar
by the way its an 88 n/a mpi 5spd manual
C.Huskey is offline
Old 02-10-2015, 11:02 AM
PNYXPRESS
PNYXPRESS's Avatar
check your throttle body and make sure the blade is able to move freely without sticking.
PNYXPRESS is offline
Old 02-11-2015, 07:13 PM
15Mustang
15Mustang's Avatar
I agree, sometimes the dealers have the best equipment to diagnose. Dealers can be cheaper in the long run if they find it right away
15Mustang is offline
Old 02-11-2015, 07:47 PM
PNYXPRESS
PNYXPRESS's Avatar
A dealership isn't gonna have a clue how to work on a 88 mustang. Their diagnostic tools won't plug into it and they will be lost.
Old 02-18-2015, 11:56 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
has a koeo/koer test been run to check for codes?? ALSO DID YOUR MECHANIC CHECK FOR VACCUM LEAKS?? sounds like a lean part throttle hesitation....we use a smoke machine to check for such.
mjr46 is offline
Old 02-18-2015, 11:58 AM
mjr46
mjr46's Avatar
it depends on who works there..........all that is needed for diagnosis to begin is either a scan tool for obd 1 or the paper clip method to run a koeo/koer test to check for codes...after that most will still have a break out box to check all input PIDS.
mjr46 is offline
Granatelli Sales
01-20-2020 12:34 AM
mustangchef
09-04-2015 08:08 PM
amandahchase
09-03-2015 10:09 AM
cbird1177711
09-02-2015 08:51 PM
iculookin
09-02-2015 12:34 PM
Quick Reply: stock 2.3 issue
