Im redoing a 1989 Lincoln Mark VII, although its not a mustang, I know you guys all know the drivetrain really well.
First thing I plan on doing is my transmission. It has the AOD, but its overdrive is done, and shifts are not great. I want definately want to go to a stick. The T5 is a pretty easy swap I'm told, but I was reading an article about an old 1971 mustang buildup and they used a T56 from a viper. Now I dont ever plan on putting out GOBS of power, but i do like the prospect of tighter rear end gears and a 6th gear to account for that on the highway. The article quoted under 2000rpm at 75 mph with 4.11 gears i think.
Im VERY new to the car, but i love it!
If you guys can me some advice, dosnt have to be on the 6 speed, just i for sure want to go stick, other than that im open to suggestion!
thanks in advance for your help
Jeff
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
I am a bit concerned about using the Borg t5, due to the extra weight. Im told the tremec TKO would be a stronger better bet. From what i can see the tremec should run about 1800 and the T56 about 2500.
tremec and borg are the same deal. i've rebuilt a few 56's in vettes, but theyre a little different than 56's out of cobras and camaros. vette trannys are in the rear of the car.
ok well after some looking, i realize the T56 they used in that article had the 0.5 6th gear, from the viper. That transmission is running about $3700 and i cant justify that. The 2500 for the t56 from tremec would be doable but its got a 0.62 6th and the TKO 600 has a 0.63, so its clearly not worth the money for me.
The difference between the Borg and tremec T5s may be negligable, but what about the TKO series? im assuming there a better transmission considering they are running 800-1000 more than the borg t5.
this is what im now questioning, is the TKO 1000 dollars better than the t5?
thanks again guys for the help, I really appreciate it! I know its not a mustang
