Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-25-2006, 02:54 AM   #1
hot85fifty
Default Weight Reduction
I have a 85 GT convertable and i was wondering what the best things to do to lighten my car? Without spending to much money. Also what are the best things to do if money was not a problem. THANKS
__________________
Twisted Wedge heads, stage 1 cam, Air-Gap manifold, underdrive pulleys, DSS pro bullet 331 stroker, main support, windage tray, G-Force drag radials, 3.73's, Holly Street avenger carb, NS Kit 100-175 shot...
hot85fifty is offline   Reply With Quote
Old 09-25-2006, 02:58 AM   #2
vida50
Default RE: Weight Reduction
Get some fiber glass body parts like HOOD, doors trunk etc...
vida50 is offline   Reply With Quote
Old 09-25-2006, 03:10 AM   #3
ckyguy68
remove spare tire and jack
__________________
89 5spd
Bolt ons
150 shot
New video check out my other streetfire vids!
http://videos.streetfire.net/video/50-Mustang-vs-B16-Civic_161426.htm
ckyguy68 is offline   Reply With Quote
Old 09-25-2006, 11:49 AM   #4
OJMiles
Depending on what your plans are with the car and how much "drivability" you're willing to lose...
Remove A/C and SMOG equipment
Remove Power Steering
Remove rear seat
Remove Spare tire & jack
Get a lightweight battery AND move it to the back... Odyssey makes a 25lbs battery thats rated for every day driving/starting duty... I'm told that they're pretty nice...
Spending a little more money you could go with a fiberglass hood, and spending even more money you could step up to aluminum heads...
All this together I'm willing to bet would set you back 150lbs or more, mostly removed from the front of the car, where you need it most.
__________________
-- OJM, NREMT-P, Richmond, Virginia
93 Mustang GT White w/ Grey leather
YOUR HEARTBEAT NEEDS CPR
Check out: My Mustang & Other vehicles
OJMiles is offline   Reply With Quote
Old 09-25-2006, 12:47 PM   #5
georgiaguy246
fiberglass the whole body, remove the spare tire and jack, and also gut out the interior then you'll loose some weight lol.
__________________
1992 Lx Hatch, auto stock
RIP 07/29/07 1987 gt hatchback, 5 spd. stock
local club for southeast folks! check it out! http://www.musclecar-evolution.com
georgiaguy246 is offline   Reply With Quote
Old 09-25-2006, 12:57 PM   #6
88BlueGT
1993 Ford Mustang
It depends what you are using the car for and how into you want to go....
Fiberglass Hood
Fiberglass Hatch w/ Lexan Hatch Window
Remove tar junk from interior (under the carpet)
Aluminum Heads
Eliminate PS
Eliminate AC
Spare Tire & Jack
Rear Seat Delete
Battery Relocation (not shedding weight but transferring it)
Fiberglass Fenders
Tubular K Member
Tubular A Arms
Disk Brakes
Supposvdly, with D&D's front end kit (k member, a arms, coil over and drag brakes) you can loose up to 140lbs with that alone. Now do all the other things and you have a 2,XXXlb car!
__________________
88BlueGT is offline   Reply With Quote
Old 09-25-2006, 07:41 PM   #7
TonyT3hSleeper
Send a message via AIM to TonyT3hSleeper
Actually having the drums in the back will take off .2 seconds, the same amount of time the 1/4 mile that removing 100 lbs of excess weight and you could prolly get another .2 seconds if the front has drums as well
__________________
1985 GT convert -auto
TonyT3hSleeper is offline   Reply With Quote
1993, body, camaro, fiberglass, fox, hatch, lexan, list, loose, mustang, rear, reduction, saving, weight, window
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
