Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-12-2006, 04:33 PM   #1
Arno
Default E303 cam and idle?
Picked up an 89 LX 5.0 that is supposed to have a 303 cam and no other mods, other than exhaust and K&N. The idle isnt the best but of primary concern is the lack of a fast idle when cold. What should I look for to correct this?
What kind of idle should I expect to achieve with this cam?
__________________
89 LX 5.0, 5 spd
Arno is offline   Reply With Quote
Old 10-12-2006, 04:43 PM   #2
88blackgt
Default RE: 303 cam and idle?
303? there are several ford cams w/ "303" in them.
http://www.fordracingparts.com/parts...rtKeyField=899
guessing its an E since they're really common and have been around forever
88blackgt is offline   Reply With Quote
Old 10-12-2006, 04:46 PM   #3
Arno
E is correct.
__________________
89 LX 5.0, 5 spd
Old 10-12-2006, 04:59 PM   #4
88blackgt
You can take a voltmeter and put it to 2 wires going into your TPS, it should .98. I dont know which color goes with which probe and my car isn't near me so I can't go look. I'll try and see if I can find it.
Old 10-12-2006, 05:02 PM   #5
92GreyGT
Green and black.
__________________
1992 Mustang GT 3375 lbs. w/driver
DSS 331 AFR 165 heads
Comp Cams XE274HR cam
Trick Flow Track Heat intake
Astro Performance Super T5 4.10 gears
Best time 7.58 @ 90 / 11.89 @ 113
333rwhp 357rwtq
92GreyGT is offline   Reply With Quote
Old 10-12-2006, 05:02 PM   #6
Arno
Does that control the fast idle?
__________________
89 LX 5.0, 5 spd
Old 10-12-2006, 05:07 PM   #7
92GreyGT
Does it stall when it's cold? When it warms up does it idle ok? If it only idles slow when it's cold and fine when it's warm I wouldn't worry about it.
__________________
333rwhp 357rwtq
Old 10-12-2006, 05:58 PM   #8
Arno
It does idle ok when warm. The idea of the fast idle when cold is to circulate the oil faster through the engine. About 1200 to 1500 rpm for 20 seconds. They do it stock, what has changed?
__________________
89 LX 5.0, 5 spd
Old 10-13-2006, 12:07 AM   #9
wythors
Good god people! Where's the basic 5.0 knowledge on this board?
Your cold idle is controlled by the "idle air control" valve, often referred to as the IAC. It's the tubular shaped thing with the electrical connector at the bottom mounted on the front side of your throttle body. I had the same problem a while back. I took the IAC off the throttle body and removed the electrical solenoid (held on with two screws) from the bottom. Then I flushed the crap out of the top half with brake clean. Let it dry and now it works like a charm and my cold idle is great. The piston inside the IAC gets gummed up with carbon and other crap over the years. The brake clean will clean all that out and you should be good to go.
__________________
1993 5.0 LX 'Vert
GT-40X303 heads, E-cam, 1.6 roller rockers,
Cobra intake, Edelbrock 65mm t/b, 73 mm C&L, CAI,
24 lb injectors, AFPR, 3.73's, March underdrives.
FRPP headers, Bassani catted X, SLP Loudmouth.
Pony R's with Eagle ZR's.
wythors is offline   Reply With Quote
Old 10-13-2006, 12:10 AM   #10
dillon1340
Vehicle: 1989 LX
Quote:
ORIGINAL: wythors
like pulling the codes before you start taking things apart....
__________________
1989 LX
dillon1340 is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
