Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-26-2006, 04:13 PM   #1
Highplanezdrifter
Default clutch making noise?!
hey guys, i just fired my car up leaving the gym and at first i was like, "wtf?!" it sounded almost like my motor had a small knock in it but not as loud. i decided to step on the clutch and the ticking stopped, then when i released it, it started doing it again. anyone have any idea what this is? throwout bearing maybe??
Highplanezdrifter is offline   Reply With Quote
Old 10-26-2006, 04:16 PM   #2
Ninety5five0
Vehicle: 1995, Ford, Mustang GT
Send a message via AIM to Ninety5five0 Send a message via Yahoo to Ninety5five0
Default RE: clutch making noise?!
sounds like the throwout bearing to me.
__________________
TOTALED
Got another 95 GT droptop about a year ago. Pic soon. Currently swapping motor.
Ninety5five0 is offline   Reply With Quote
Old 10-26-2006, 04:43 PM   #3
Highplanezdrifter
any ideas on how to fix this problem??
Old 10-26-2006, 04:56 PM   #4
fourfivefour
Pull the trans and disconnect shift cable. Remove the throw out bearing and spin it to see if it is dry. Replace the throwout bearing.
__________________
fourfivefour is offline   Reply With Quote
Old 10-26-2006, 05:00 PM   #5
Highplanezdrifter
damn, i'm definently not looking forward to another 8 hours worth of work on the clutch again. i just put the clutch in about a month and a half ago!
Old 10-26-2006, 05:06 PM   #6
fourfivefour
Did you replace your pilot bearing? Dont say you just greased it. It could be making noise too.
I did my clutch last weekend along with other mods. I don't know how old it was. My throwout bearing would make a sqeeking sound unless I rested my foot on the clutch. The bearing was in pieces.
__________________
Old 10-26-2006, 05:30 PM   #7
silver91gt
your clutch needs to be adjusted, it is the throwout bearing barely making contact with the pressure plate fingers.
if you have a stock clutch cable setup then just livt up on the clutch pedal and press it a couple of times.
__________________
novi powered 347 11.6@121mph
with a little spray 10.7@130mph
silver91gt is offline   Reply With Quote
Old 10-26-2006, 08:32 PM   #8
Highplanezdrifter
i did everything in one shot and got a new cable and firewally adjuster at the same time. i will adjust the cable and see if i can get it to stop doing it. i replaced my pilot bearing also.
Old 10-26-2006, 08:36 PM   #9
sc94gt
Once you get the squealing it's pretty much shot.
Make sure when you adjust the cable to leave some play in the clutch pedal.
As the cable stretches, pay attention and tighten it accordingly, especially a new cable.
__________________
94GT 5spd
291hp/330tq
BBK u&l contrl arm
Eibach/KYB shock/Energy Susp sway/bush
6lb Ford Racing SC
Pro 5.0
Mac equals/H-pipe/cats
Spec Stage II
Cobra brakes
Eaton dif w/31 spline 3.73
BBK subfr. con.
MSD
FR alumn. d/s
13.5@103
sc94gt is offline   Reply With Quote
2000, clutch, gt, making, mustang, mustangnoise, noise, pressing, step
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
