all right i have the speed i want now i think its time to take tight corners... i dont plan on doing autocross or anything like that just want to be able to take turns with a little more umph. im on a tight budget as any teenager is so i have started to look at ebay brand **** which i know is rule no.1 on the list of things not to do but im desperate... so far im thinking about lowering springs, sub frame connectors, new struts for the front, and strut tower brace. so far thats what im looking at. if anyone has any suggestions or advice they would like to share i could always use some imput. Thanks guys
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
"When the GREEN light drops, the BULL**** stops" - John Kingston
Some more things are (I am doing do this to my car)... Better rear control arms, front sway bar bushings, & high end bushings for your new springs. The spring bushings help more than one may think, and are cheap. Newer, better bushings will really help these older cars. Control arms aint cheap, but bushings are. Performance sway bars will also help.
id say look into a new k-member. saves weight stock compared to an aftermarket one, and stiffens up the front suspension a bit. that along with the sub fram connectors, rear control arms, strut tower bar, new front stuts, and lower springs should make a pretty big difference. fox bodys are already pretty balanced cars actually, they just dont have the greatest stock suspention and are a bit heavy.
__________________
MAC Long Tubes, MAC off road H-pipe, B&M Pro Ripper short shifter, flowmaster cat back, underdrive pulleys, and a little stereo =]
I dont know if its out of your budget, but QA1 sells a kit to to convert your car to a coil over setup with tubular control arms and k member for like 1000 bucks. Id get that and rear control arms. Get polyurethane everywhere too and you should be ready to rock. FRPP also has the handling pack, shocks, struts, springs, and sway bars for mustangs for like 400 bucks.
__________________
Tunable Inductions CAI, 245/40ZR18 Sumitomos in front with 275/40ZR18's in the rear, X-Pipe, Flows, BBK Shorties. 255LPH BBK fuel pump. PRO 50 Shifter. Ford Racing 3.73's w/ carbon fiber T-lok clutches.
k member for sure, i would say it never hurts but for handling i dont know that suframe connectors would really do a whole lot they are more for stopping frame twist drag racing.
__________________
HISTORY IS DESTINED TO REPEAT ITSELF AND YOU WANNA RACE ME AGAIN
Actually sub frame connectors will help! The purpose of the sub-frame connector is to stiffen the chassis. A torsionally stiff chassis will keep a more even load on all wheels to improve traction . Not just in straight line cars but for cars connering as well ..
__________________
"You can have it in any color you want. Long as its Black!"
84gt, 87gt, 91Lx, 92RS 25th ann, Among others!! http://www.myspace.com/shadowfoxsky
Weld up the factory torque plates (stock is just tack welded), weld in full length subframe connectors, upper/lower control arms, lowering springs, & a strut tower brace. Those are all fairly basic things someone can do on a budget. K member's take quite a bit of work and are fairly expensive, although they are great weight reduction and improve handling.
here is the cheapest way to increase handling by about 100% for not to expensive (maybe $600 + your time)
eibach lowering springs, energy suspension full poly kit, and kyb's at all corners. just the cheap kyb's make a huge diff w/ the rest you don't need the expensive ones.
__________________
'93 calypso notch 6th stang and counting
nitrous oxide is proof there is a GOD and he wants us to be happy
