Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-06-2007, 09:57 PM   #1
OPIATE5.0
Default Fuel smell
Hey guys I have a 93 lx 5.0 and have a fuel odor. I was wondering if it possibly would be the filter thats dirty... Any help would be great...
Rob
OPIATE5.0 is offline   Reply With Quote
Old 04-06-2007, 10:04 PM   #2
92hatchLX
Default RE: Fuel smell
A dirty fuel filter has nothing to do with a fuel smell. Do you smell it while the car is running? Is the smellcoming out of the exhaust pipes or is it a fuel leak?
__________________
I do ultra-sonic reverse flow injector cleaning and rebuilding, pm me if interested
92hatchLX is offline   Reply With Quote
Old 04-06-2007, 10:04 PM   #3
vtecwho
check the box adjacent to the smog pump. i believe that box is used to absorb fuel vapors and if something came unplugged then that MAY be your problem.
__________________
AFR 165s, E 303, COBRA UPPER/LOWER, #24 injec, Z3X ECU, twEECer, VORTECH v-1, 5lbs & FMU
vtecwho is offline   Reply With Quote
Old 04-06-2007, 10:13 PM   #4
OPIATE5.0
Yeah 92 Hatch, i smell it while its running, seems like maybe its coming from the exaust... When I sit in the drivers seat while the car is in the Garage (with the door open...Wanted to clairify that incase of a smart ass remark from anyone) I can smell it and when I get home from work and turn the car off, there is still some odor for a few minutes... I'll check that box "vtec", that would be nice if it was that simple... Not my luck though....
Rob
Old 04-06-2007, 10:18 PM   #5
OPIATE5.0
The guy I bought it from a few years ago said that the gas smell came from the high flow cats that are in there. Personally it doesn't sound right to me...
Old 04-06-2007, 10:24 PM   #6
90Lxstanger
My car stinks bad sometime. I think no cats. might have somthing to do with it- that and the hole in the rear hatch from where the pump was installed probably needs sealed up better- And the bottom of the door seals are gone......i need to just fix a few things thought that would help
__________________
90Lxstanger is offline   Reply With Quote
Old 04-06-2007, 10:25 PM   #7
91lxstang
91lxstang's Avatar
Vehicle: 1995 Formula Firebird 6 Speed
Send a message via AIM to 91lxstang
my freind put a high flow cat and full exhaust on his 95 lt1 formula and now it reaks of gas...... maybe it is the cat lol but no it doesnt sound right
__________________
1995 Formula Firebird M6
GM847 cam, ported tb, accel #36 inj, le intake, le2 heads, cc pushrods, cc pro mag rockers 1.6, patriot extreme gold springs, ls7 lifters, trickflow gp's, lt4 timing set, 100 shot, centerforce df clutch, pro 5.0 shifter, black zo6 wheels, tinted tails, 5% tint
91lxstang is offline   Reply With Quote
Old 04-06-2007, 10:33 PM   #8
backfire2007
Im running flows w/ no cats and I smell a little gas while in the
garage
but if it hurts your eyes, one of your oxygen sensors is probably out
been there done that
run a computer diagnostic, it will come out
__________________
93 GT auto
TFS-1cam,TrackHeat Heads,Holley Systemax Int.,70mm t/b, 24lb. inj.,75mm MAF,190lph, shorties and flows, msd. dist., coil, 6al, CAI, 4.10's,
backfire2007 is offline   Reply With Quote
Old 04-06-2007, 10:34 PM   #9
samseed101
having no cats will increase exhaust / gas smell but it shouldnt be as bad as you say. You may be running rich. That coupled with the high flow cats would cause that. Or you could actually have a leak somewhere. Maybe bad o-ring near the injectors, leak in return line, bad charcoal canister, etc.
But if its coming from your exhaust like you say, check to make sure you're not running too rich.
__________________
Car @ idle
NOS is like a hot chick with an STD. You wanna hit it but you're afraid of the consequences.
samseed101 is offline   Reply With Quote
Old 04-06-2007, 10:34 PM   #10
91lxstang
91lxstang's Avatar
i run no cats on my hatch to and smell alittle gas but not so much that my eyes want to explode
__________________
36lb, 50, fmu, injectors, mustang
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
