Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-06-2007, 04:28 PM   #1
92whitelightning
Default water/meth injection
i am looking into gettting a stage 2 snow performance kit..just wondering if i took it to the speed shop to get it dyno tuned once and done if that was alright...and they would be able to tune it ....just wondering because alot of people are running self tunable computers and i dont have one
__________________
Mods: AFR 165,Paxton SN2000,BBK SSI Manifold,70mmTB,42lb,KirbanFPR,Alum.Driveshaft,4.1 0,1.6rr,3.5 dishcharge tube, vortec bov,oil cooler,modified inpeller,MSD ig.,centerforce DF clutch, eibach springs, ARP studs,80MM C&L MAF, Walbro 255LPH pump....
92whitelightning is offline   Reply With Quote
Old 08-06-2007, 04:39 PM   #2
only90s
Default RE: water/meth injection
Quote:
ORIGINAL: 92whitelightning
I recommend getting a SCT Chip.....I have 4 tunes on my chip.....you are going to want to be able to switch from the Meth tune to normal pump gas tune, just in case you ever run out of the Meth...of course I never run out so I never really take my switch off the Meth tune. Tuner can adjust for 87 octane, 93 octane, Meth..no Meth etc...
http://www.sctflash.com/product_chip.php
__________________
90 GT, 5spd, 4.10s, Vortech 10lbs, 308 Twisted Wedge, TFS Stage 1 cam, Holley Systemax, 42lb injectors, Power Pipe, SCT Chip 461rwhp/434rwtq..
90 Notch-Paxton, 355 gears, flowmasters-sold 9/94
only90s is offline   Reply With Quote
Old 08-06-2007, 04:40 PM   #3
bz1111
What kind of numbers are you expecting from methalnol injection and what size shot are you running and how much did you pay for it.
I have been wondering about methanol alot My buddy's dodge 2500 deisel has it and he is pushing 450 hp with 850 torque. He claims that it lowers the combustion temp by almost 200 degrees.
__________________
1990 LX vert
93 notch conversion in progress
347 stroker tko 600 Vortec supercharger underway
bz1111 is offline   Reply With Quote
Old 08-06-2007, 04:49 PM   #4
only90s
I got another 60 horse when I added Meth to my set up. You basically gain horsepower because you are able to run more timing due to the cooler intake temp and the increased octane level.
__________________
Old 08-06-2007, 04:52 PM   #5
92whitelightning
yea they claim 30+....it all depends apon the application that you have....
how many PSI are you running ONLY90's?
__________________
Old 08-06-2007, 05:07 PM   #6
only90s
11 pounds....the actual number is 56 more horse...but the real benefit is no Detonation...I am running the Anderson Motorsports Mr. Freeze...it runs on boost/vacuum and not electronics like the Snow Kit.
__________________
Old 08-06-2007, 05:25 PM   #7
92whitelightning
nice i'll look into that one and compare
__________________
Old 08-06-2007, 07:35 PM   #8
LX 90
LX 90's Avatar
Vehicle: 90' Mustang
Send a message via AIM to LX 90
How does it work?? is it like nitrous??
__________________
H/C/I, C4 Trans, 4:10s, MAC longtubes W/ prochamber,
custom burned SCT chip
375-RWHP/393-RWTRQ 11.60 @ 114
LX 90 is offline   Reply With Quote
Old 08-07-2007, 02:05 PM   #9
92whitelightning
i mean if u look at it in a way it would be somthing like a 50shot but in the same way it isnt anything like it....when compressing air in a Centrifical SC or turbo without an intercooling system your just forcing hot air into the motor ..hot air means - power....your gains are minimal....a water/ meth kit is a chemical intercooling systemthat you can have it run off an adjustable boost controller or a boost/vac line...and u set for the chemicals to be spray at whatever boost level you want to hit....the meth will increase your octane levels as the water will cool the compressed air and evaporate before it reaches the cylinders..allowing you to get the most possible gains out of your boost...
__________________
Old 08-07-2007, 02:11 PM   #10
92whitelightning
see i have a old school Paxton SN2000 it is ball driven inside unlike the newer blowers that are gear...and i just recently put on a smaller pulley to give me more boost...but the negetive side is that this is also spinning my internals a little faster and there for heating up the self-contained oil cooking the air as it comes in...so this is where a snow kit or any other brand of water/meth would come into play...it I were to run custom pipes for an air- air intercooler all of those bends in the pipes will actually make me loose boost and so would i if i went with a air-water aftercooler.......the more bends in a pipe the more the air is going to slow down....so im choosing to go with a water/meth intercooler
__________________
chemical, freeze, horsepower, intercooler, mr, paxton, sn2000, supercharger
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
