Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-25-2005, 04:25 PM   #31
Quik
Send a message via AIM to Quik
Default RE: Junkyard performance
also a stock 92 LX coil is actually a strong coil better then some aftermarket ones. Crane fireball ignition uses one in their kits
__________________
powershifting owns....
o yea if your car doesent break ur not driving it like u should
Quik is offline   Reply With Quote
Old 04-26-2005, 03:46 AM   #32
Demon_Mustang
Yah, I replaced my coil with the MSD but kept my old one just in case.
Demon_Mustang is offline   Reply With Quote
Old 04-27-2005, 06:27 AM   #33
FoxGT
Vehicle: unicycle
Send a message via AIM to FoxGT
Quote:
ORIGINAL: fast83gt
Probably can't find many in a junkyard though
Quote:
ORIGINAL: Demon_Mustang
Don't think I'm trying to be mean by saying this: Try to keep the post with just tips, so if people look at things they can do by going to the salvage yard, they won't see alot of posts like "I did that to mine" or "I've been wanting to do that" ect... It's basically just useless posts. & Plz do not take this the wrong way. I'm not trying to get anyone mad at me or start a fight. Just keep it "junkyard performance" advice posts. No need to reply to this, all it will do is fill up a good thread with useless crap.
More mods:
the four-speed box fitted to 1979-'82 V8 cars can (and should) be replaced by the Borg-Warner T-5 five-speed fitted in later cars. The 1983-'84 T-5 close-ratio boxes are not super-attractive either, because of reliability problems; the 1985-'89 T-5s are a little better, but are still a little weak; the 1989-up T-5s are a good choice and are easy to find in salvage yards; the T-5 fitted in the limited-edition Cobra and '93 high-output Mustangs features even stronger guts; and the Saleen Mustangs came with the very desirable World Class close-ratio five-speed.
Clutches also improved through the years, with the 1986-up 10.5-inch clutch assembly and flywheel being the preferred choice over the earlier 10-inch setup. The later flywheel and clutch will fit all earlier V8 Mustangs except the 1979 version.
Also, if you have a GT and are tired of looking at the louvered taillights, the smoother ones offered on LX models swap right in. Ditto for the current-generation SN95 cars; the 1996-'98 retro-look rear lights will replace the 1994-'95 pieces.
__________________
If you have to ask what it takes to get to 500 HP, you don't have what it takes to get there.
'89 Mustang GT
'86 Mustang vert
'84 TT 351w notch
'89 Turbo Ranger
'96 Musta
FoxGT is offline   Reply With Quote
Old 04-27-2005, 06:59 AM   #34
FoxGT
Vehicle: unicycle
351C heads will offer alot of power, but requires some machining & a different intake manifold. Here is a link to what is required. http://www.themustangshop.com/clevor.cfm
V70, S60 , S80, S70, Volvo fans are a good replacement fan, awesome cooling & very cheap. They are electric & flow alot of air. They can be made to fit very easily.
__________________
'89 Mustang GT
'86 Mustang vert
'84 TT 351w notch
'89 Turbo Ranger
'96 Musta
Old 06-03-2005, 03:41 PM   #35
flamin87
hey, any body know about the twin turbo set up ,using the t-bird turbo coupes??? im really interested in doing that to my 87 gt.
flamin87 is offline   Reply With Quote
Old 06-04-2005, 05:01 PM   #36
FoxGT
Vehicle: unicycle
Junkyard route TT If they will fit upside down & you have $ to do so, I would recomend replacing those unequal shorties with equal length shorties.
__________________
'89 Mustang GT
'86 Mustang vert
'84 TT 351w notch
'89 Turbo Ranger
'96 Musta
Old 06-05-2005, 01:07 AM   #37
flamin87
damn seeing that project got me amped up, does anybody know what parts you need to take off the donor turbo car that i will need to use in my car?
Old 06-05-2005, 04:26 AM   #38
Demon_Mustang
Equal lengths might not fit correctly with the spark plugs when put upside down like that. Also, with twin turbos it's not really horrible to have unequal length shorties. In fact, my friend ran in the 11's with the Mustang I bought fairly recently and it has unequal length shorties...
Old 06-05-2005, 01:30 PM   #39
stangster666
Send a message via AIM to stangster666
When doing a twin turbo setup how is the exhaust run after the turbo's and intercooler are installed. Does anyone have a picture. I mean is the h-pipe still useable?
__________________
IT'S ALL IN THE EYE OF THE BEH
stangster666 is offline   Reply With Quote
Old 06-12-2005, 07:36 AM   #40
93tripleWhiteLx
Ok, wait, you're telling me that there is a way to 'build' a twin turbo set-up using thunderbird turbo coupe parts?! If this is correct. I need more info. Because, I would love to start doing some mods like that to my basically stock stang but wouldn't even know where to begin. I mean, I know how it works but don't you have to have a custom made header that is specifically designed for that kind of a bolt on? And what about the intake? And who makes these parts... I think you're getting way to over the top with this being a 'junkyard' parts pull. The GT40 heads. It would be nice to have a list of what cars this option came on and with the added HP what needs to be done to the EECIV? And you mentioned the 98 Explorer has the same or equivilent as the cobra upper and lower intake? My car doesn't even lay scratch! It has a hard time break free in the rain! I still have ALL of my smog, A/C, and every restrictive thing on my car but I have started doing minor mods and have lost low end torque like a mofo. So, if we're going to start talking 'junkyard' lets at least stay in the realm of what is considered 'junkyard'.
The GT40 head is a good idea but for a 87-93 LX what heads will be a 'direct' bolt-on, and what heads will need mods?
Next, the T-5. I have a stock AOD and would like to actually convert to a 5 or 6 speed. Are 6 speed trannys even an option for me? Are the 87 and above T-5's on 4 bangers worth getting and building up to match the performance of an aftermarket transmission? And did they improve the quality of the 4 cyl. T-5's like they did with the T-5's from a 5.0?
I just bought a complete rear wheel disc brake conversion (4 lug) axles, new rotors, dust shields, calipers, new pads, e-brake cable, and all necessary mounting hardware off of ebay for $398, and that's with shipping. Did I get took? I read on this thread that Jeg's has them for about 400 all brand parts. The ones I was looking at though to retain 4 bolt pattern were much more than that. Did I read wrong? And are C-clip eliminators worth it while I'm doing the gears and rear brake conversion?
Thank you. j.
__________________
93 Limited LX, bone stock except for, cold air, flowmasters, timing bump, wires.
93tripleWhiteLx is offline   Reply With Quote
1987, 50, diesel, diy, explorer, ford, gt40, heads, junk, junkyard, lincoln, lsc, mustang, performance, se, turbocharged, vii, yard
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
