I bought a 90 gt convertible about 6 months ago that needed a tranny .. i put a new tranny in it and when i got it all back together i noticed a viberation around 60+ , Well i have discovered that the rear axles have play, the move in and out definatly more than they should, i am knowledgable about car but not about this rear end, i took it apart, replaced the axle bearings and seals, but with little change, Any help would be great...
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
It is normal, maybe a little extra but normal. Like I said, unless you can pull them out completly, I wouldn't worry.
Did you replace you bearings and seals yourself? I am guessing not, otherwise you would understand what is going on.
EDIT: Okay, I see you did it yourself in your first post. Remeber when you took your center pin out of the diff, then you had to push your axles in and remove the clips.....the clips keep the axles fromfalling out, the pin keeps them from pushing in. Some slop in normal. Ulsee you saw some abnormal wear to thepin or the c-clips.....don't worry
I replaced them myself yesterday, i know how it all works sence i tore it all apart, but it just seems pretty excesive. is it possible that where the c-clip rides inside the housing actually wore it down inside there a little?
