Welcome to Mustang Forums!
Welcome to
Mustang Forums .
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community,
at no cost , you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please
join our community today !
10-31-2007, 08:12 AM
Ford Torque Specs.
Okay, I posted this in the 351 Section, but to become a sticky, I think it needs to be here.
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use aftermarket performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302
Fastener Type Torque Spec
Main cap bolts 60-70 ft.-lbs.
Outer main cap bolts, 35-40 ft.-lbs.
Connecting rod bolts 19-24 ft.-lbs. (40-45 ft.-lbs. for 289 HP Boss 302)
Cylinder head bolts 65-72 ft.-lbs.
Rocker arms 17-23 ft.-lbs.
Intake manifold bolts 23-25 ft.-lbs.
Oil pump bolt 23-28 ft.-lbs.
Cam bolts 40-45 ft.-lbs.
Cam thrust plate bolts 8-10 ft.-lbs.
Harmonic damper bolts 70-90 ft.-lbs.
Flywheel/flexplate bolts 75-85 ft.-lbs.
Pressure plate bolts 35 ft.-lbs.
Front cover bolts 12-15 ft.-lbs.
351W
Fastener Type Torque Specs
Main cap bolts 95-105 ft.-lbs.
Connecting rod bolts 40-45 ft.-lbs.
Cylinder head bolts 90-100 ft.-lbs.
Harmonic damper bolt 70-90 ft.-lbs.
351C, 351M
Connecting rod bolts 40-45 ft.-lbs. (45-50 ft.-lbs. for Boss 351C)
Cylinder head bolts
(follow factory torque sequence) 105 ft.-lbs. (125 ft.-lbs. for Boss 351C)
Rocker arms (non-adjustable) 18-22 ft.-lbs.
5/16 in. intake manifold bolts 21-25 ft.-lbs.
3/8 in. intake manifold bolts 28-33 ft.-lbs.
Oil pump bolt 25 ft.-lbs.
Cam thrust plate bolts 9-12 ft.-lbs.
Front cover bolts 12-18 ft.-lbs.
429-460
Maincap bolts 95-105 ft.-lbs.
Cylinder head bolts 140 ft.-lbs.
Intake manifold bolts 25-30 ft.-lbs.
360, 390, 406, 427, 428 FE
Crossbolts for 406 and 427 40 ft.-lbs.
Connecting rod bolts 40-45 ft.-lbs. (53-58 ft.-lbs. for 406 and 427)
Cylinder head bolts 80-90 ft.-lbs. (100-110 ft.-lbs. for 1963-67 427)
Rocker arm shaft bolts 40-45 ft.-lbs.
Intake manifold bolts 32-35 ft.-lbs.
Oil pump bolt 12-15 ft.-lbs.
Hope this is helpfule to new hot rodders!
MadMan
Register your
free account today and become a member on Mustang Forums!
__________________
"All our science, measured against reality, is primitve and childlike-and yet it is the most precious thing we have."
Albert Einstein
Be On The Lookout For Avatar Theft
10-31-2007, 02:29 PM
RE: Ford Torque Specs.
Willa mod/admin put this into the tech articles?
Thank you
__________________
Albert Einstein
289 , 351 , 429 , bolt , bolts , flexplate , ford , head , intake , manifold , mustang , sequence , spec , specs , torque , tq , type
