bowl work what do you mean? all i did was gasket match the heads they are factory e7 and i ported them my self
Okay...there's a difference between actual "head porting" and just gasket matching.
On the pics I posted, you'll see the actual bowl work where the valves are removed. The air flows through the ports from the intake, into the bowls, then into the combustion chamber when the valves open.
It's okay to match the port openings to the gasket size, but it's worth minimal gains in HP. I did the same thing. Gasket matching is another part of a decent porting job.
But the actual airflow gains will be realized from the bowl work under the valves, and recontouring the transition from the bowls into the ports.
It's all worth a bit more peace of mind...working on your own stuff, it's what hotrodding is all about.
__________________
'83 Mustang GT, T-tops, 306, tweaked factory heads with 1.90/1.60 valves, RPM intake, 650 dbl. pmpr., Lunati cam, long headers, 2 chamber Flowmasters, T-5, 3.45 Tracloc...
'88 Lincoln Mark VII LSC, 5.0HO, AOD, loaded, leather, 3.27 Tracloc, no mods yet
looks like a gasket match port job...still help but that intake has to go unless you have it extrude honed......the easiest way to unshrout the valve is to go with bigger valve ....but always use the cutback valves
Talkin' to me or vfast? lol
I think vfast said you need to switch upper and lower intakes, maybe to a GT-40?
If you look in the bowls before any work is done, you can tell that material needs to be removed. But at this point, go ahead and run what you have, I don't see anyone else on here offering any decent advice, so don't listen to just me and ruin a set of heads.
There's a big difference between bowl porting and just gasket matching an aluminum intake or the head ports.
The reason I posted this was to find out if there's anyone here who actually has something to offer, I haven't seen any replies yet, just a couple vague comments.
Since I'm not a porting expert, I can't really say what's best to do, I was just showing what I did as practice. Sorry, but I guess this is dead in the water. lol[sm=lame.gif]
__________________
