do a search there is tons of info on this..google it......but here are some things needed tranny, bellhousing,clutch,flywheel, clutch fork, crossmember, clutch pedals,clutch cable, t-5 engine to tranny spacer plate
__________________
Quote:
Originally Posted by dudeboy
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
Is it necessary toswap computers also? I've heard there's a kit that includes everything necessary to achieve this. Anyone have any experience using this? I understand there's a great deal of info on here, but unfortunately the search function isn't working. The Google search bar has an option to search the website of the page you're currently viewing.
Yea, its best to change the computer form an aod ECU to a5 speedECU. I converted mine and it is prety simple.I got my ECU from a company called AMPPerformance. it wasnt that expensive and it was a quality part. you have to get an5 speedECU that is from your mustang year range (ie 87-89 or 90-93) that way it works with the other features the car has. if you are looking to save some money you can get an ECU later. the only difference between the aod/5 speed is the fule curve. the ECU is programed to match the gearing in the trans and being as the gearing betewwn the aod and 5 speed is a little different the fule curve will be a little different. so if you keep the aod ECU it will still run ok but i think its best to spent the money and get a 5 speed ECU
are you sure you need a new crossmember? i thought they were both the same
__________________
for sale, 91 notch 5.0 maroon with grey interior. auto with 85k. car is just about 100% stock only exhaust is aftermarket. located in plymouth, mass
