Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-09-2005, 01:29 PM   #11
mdvaldosta
I ♥ Acer
Default RE: glowing headers after cam install.
no its unburnt fuel burning up in the headers... either ign timing retarted or cam timing off
mdvaldosta is offline   Reply With Quote
Old 03-09-2005, 01:30 PM   #12
Tims 88GT
Send a message via ICQ to Tims 88GT
im with 69mach, it sounds lean or it is sucking air somewhere making your fuel mixture lean, also on the timing gear (ON THE CRANK) did you make shure the little 0's were lined up with the cam gear????? if not i would say you have the cam timing off, their is a few different slots in the gear. How do you know the motor is on tdc? what did you do to get it their? sry thats kinda a dumb question, cose it shouldent fire if it is way out.
__________________
2003 Cobra.
Pretty much stock.
Exhaust, tuner, shifter, jlt= 12.3's at 116 or so mph
Quote:
ikeybmg
chatterin is just like... i dunno, taking a tator chip bag and crunching the heck out of it.
Tims 88GT is offline   Reply With Quote
Old 03-09-2005, 01:34 PM   #13
angcobra
Quote:
ORIGINAL: mdvaldosta
Agree.
__________________
03 MG Cobra Vert, 448 RWHP 478 RWTQ
JLT CAI, MAC 3" Catbacks
2.80 pulley, Diablo Predator custom
MGW shifter, red handle
Lots of Bling
angcobra is offline   Reply With Quote
Old 03-09-2005, 01:53 PM   #14
FiveOhNo
i didn't see anywhere in your post where you said you checked the timing with a timing light...you can't just go by 'it points this way'. get out a timing light and see exactly where your timing is. it should be advanced 10* for factory specs. if that's right, then it's in your cam timing. to get you started...the rotor in the distributor should point to the number one spark plug wire on the cap (while the engine is on tdc). that should get it started and allow it to warm up to operating temp. then get out the timing light and fine tune the timing.
__________________
91' GT (my baby) Trickflow Trackheat Intake, Pypes Exhaust
96' GT (for sale $6,500)
89' 240SX SR20DET my auto-x/drifter
FiveOhNo is offline   Reply With Quote
Old 03-09-2005, 03:56 PM   #15
C/Note
I ♥ Acer
dam i thought all headders glowed at night [&:]cause there thin
C/Note is offline   Reply With Quote
Old 03-09-2005, 06:29 PM   #16
LLADNAR
actually that would cause the opposite effect,,too much fuel will actually cool your egt's instead of raising them,,,it is rnning way too lean. I am a former import turbo guy who has run into this before if you are running a massive amount of air and not enough fuel you can watch the egt gauge peak off the chart, same goes for ignition too advanced means early lightoff, detonation, and massivly high egts
__________________
88 Mimosa yellow LX 5.0 Auto 1 of 127,Hooker Comp headers,Off Road H-Pipe,Magnaflow mufflers 3.73 Motorsport gearset,Granetelli 110lph fuel pump,airpump removed,,,Mac Underdrive pulleys,,,K+N intake,,, Pony Wheels Best time of 14.98@93.5mph
LLADNAR is offline   Reply With Quote
Old 03-09-2005, 07:38 PM   #17
Tims 88GT
thats y i say he has his cam timing off and or he is sucking air somwhere, it happend to my uncle with his shelby.
__________________
2003 Cobra.
Pretty much stock.
Quote:
ikeybmg
Old 03-09-2005, 10:39 PM   #18
silver91gt
the first time I started it after the cam install I did time it with a timing light, and put it to the factory spec 10 degrees advanced. my problem is I forgot to mark where the distributor was before I took it apart. So I think I have it in the wrong direction.
could someone put their motor to TDC and let me know where your rotor points relative to the intake.
thanks, I will check for vaacum leaks. I heard I can use propane, is this safe, or can I just use some brake/carb cleaner?
__________________
novi powered 347 11.6@121mph
with a little spray 10.7@130mph
silver91gt is offline   Reply With Quote
Old 03-09-2005, 10:46 PM   #19
Tims 88GT
i would just use carb cleaner, i still say that your air/fuel ratio is lean
__________________
2003 Cobra.
Pretty much stock.
Quote:
ikeybmg
Old 03-09-2005, 11:55 PM   #20
silver91gt
to find TDC I just took out the #1 spark plug and put my finger over it while rotating the crank clockwise to feel when it is in compression stroke, and then go till the timing mark lined up with the 0 on my balancer.
__________________
306, b303, camshaft, chain, ford, glow, glowing, headers, hot, idle, installation, motorsports, mustang, red, start, supercharger, timing, worn
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
