Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-10-2005, 03:29 AM   #21
91hatchgt
Default RE: glowing headers after cam install.
I just did a new intake, and when I took it off, at TDC my rotor pointed towards the runner on my intake, almost straight back relative to the car.
__________________
94' GT - 331, TW Stg. 2 heads, C.I. cam, 1.6rr, Tubular GT40, 24#, 75mm PMAS, 70mm TB, BBK Shorties, O/R X-pipe, Flowmasters, MSD TFI, Pro-kit, Spec Stg. II, B&M Ripper
91hatchgt is offline   Reply With Quote
Old 03-11-2005, 03:16 AM   #22
silver91gt
cool thanks.
__________________
novi powered 347 11.6@121mph
with a little spray 10.7@130mph
silver91gt is offline   Reply With Quote
Old 03-11-2005, 12:09 PM   #23
83GT306
Quote:
ORIGINAL: silver91gt
to find TDC I just took out the #1 spark plug and put my finger over it while rotating the crank clockwise to feel when it is in compression stroke, and then go till the timing mark lined up with the 0 on my balancer.
That is correct. When you get that mark lined up to the 0, remove the dizzy cap again and see where the rotor is pointing, there should be a "1" on the cap. The firing order is 13726548 counter-clockwise.
If it's not pointing at the #1, remove the dizzy and retry until you get it right. It's not that difficult. Just position the TFI module on the dizzy in a way that you can rotate it after the engine starts to adjust your timing with a light. Don't forget that the little plug in module that hangs from the distributor wiring(can't think of what it's called)needs to be removed from the plug to set the base ignition timing to 10*, then plugged back in.
If the engine still won't run, tear it down again to see if you left any vacuum lines off and to check your timing gear marks again. There are a bunch of vacuum connections under the upper intake, make sure none are leaking.
__________________
'83 Mustang GT, T-tops, 306, tweaked factory heads with 1.90/1.60 valves, RPM intake, 650 dbl. pmpr., Lunati cam, long headers, 2 chamber Flowmasters, T-5, 3.45 Tracloc...
'88 Lincoln Mark VII LSC, 5.0HO, AOD, loaded, leather, 3.27 Tracloc, no mods yet
83GT306 is offline   Reply With Quote
Old 03-11-2005, 12:13 PM   #24
C/Note
I ♥ Acer
if it runs good dont worrie about it....[&:]
C/Note is offline   Reply With Quote
Old 03-11-2005, 09:06 PM   #25
taekwondodude
That happen to me once (pain in the butt) and it turned out that the timing was off my just a little
taekwondodude is offline   Reply With Quote
Old 03-11-2005, 09:28 PM   #26
silver91gt
what do you mean don't worry about it, my headers get soo hot they glow, I could light a cigarette from a foot away they're so hot.
I will have to take off my valve cover and make sure it is on the compression stroke and not the exhaust stroke.
I might have it firing on the exhaust stroke.
if thats possible.
__________________
Old 03-11-2005, 09:30 PM   #27
fats429
Vehicle: 1966 Ford Fairlane 1990 Mustang LX Coupe
Send a message via AIM to fats429
na bro if you wer fireing on the exhust stroke it would not eaven start
fats429 is offline   Reply With Quote
Old 03-11-2005, 11:01 PM   #28
69mach1377
1969 Ford Mustang
yer runnin too lean...
__________________
69Mach1-SteetBoss377 Clevor,351W blk/stroker crank,10:1cr,351C-2V hds,2500 stall FMX,3.50:1 posi,rack&pinion/tilt,17x8 Mach1 Rims(2003),all MSD,Holley750,custom paint,Shelby drop,Cam Adv
http://photobucket.com/albums/v618/danaranda
69mach1377 is offline   Reply With Quote
Old 03-12-2005, 12:08 AM   #29
Tims 88GT
Send a message via ICQ to Tims 88GT
exactly just listin to 69mach and i that is your problem i bet money on it.
Quote:
ORIGINAL: 69mach1377
__________________
2003 Cobra.
Pretty much stock.
Exhaust, tuner, shifter, jlt= 12.3's at 116 or so mph
Quote:
ikeybmg
chatterin is just like... i dunno, taking a tator chip bag and crunching the heck out of it.
Tims 88GT is offline   Reply With Quote
Old 03-12-2005, 10:43 PM   #30
silver91gt
I found a leak in my upper-lower intake and have to fix it on monday
I will try making a gasket from gasket material.
__________________
306, b303, camshaft, chain, ford, glow, glowing, headers, hot, idle, installation, motorsports, mustang, red, start, supercharger, timing, worn
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
