Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-09-2008, 06:15 PM   #1
warggod
Default E303 CAM.... please help
can i run a e303 cam on my stock motor meaning stock push rods and stock rocker arms
because i no im a little tighter now on my rockers please help no body seems to no
do i need shimms
p.s. 498 lift
warggod is offline   Reply With Quote
Old 02-09-2008, 07:15 PM   #2
92GreyGT
Default RE: E303 CAM.... please help
I guess you can get away from using your stock rockers but I would reccomend getting a set of roller rockers. Pushrods should work but I would check the rocker geometry. Without a doubt you will have to have valve springs. What are your other mods? If you are just putting a cam in a stock engine you aren't going to see any performance improvement just a lumpy idle.
__________________
1992 Mustang GT 3375 lbs. w/driver
DSS 331 AFR 165 heads
Comp Cams XE274HR cam
Trick Flow Track Heat intake
Astro Performance Super T5 4.10 gears
Best time 7.58 @ 90 / 11.89 @ 113
333rwhp 357rwtq
92GreyGT is offline   Reply With Quote
Old 02-09-2008, 07:16 PM   #3
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
CAM CHANGE = VALVETRAIN UPGRADE= SPRINGS, LOCKS and RETAINERS......with that you may have to clearance the factory rockers for reuse........and when setting up valvetrain you always should check for proper geometry..don't short cut it
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 02-09-2008, 08:40 PM   #4
warggod
couldnt i just get smaller pushrods to make up the differents in lift from the bigger cam
Old 02-09-2008, 09:01 PM   #5
92GreyGT
What are you trying to accomplish with the bigger cam? No, different length pushrods are to correct rocker to valve tip geometry it has nothing to do with valve lift. If you wanta bigger cam you have to have valve springs, retainers, and locks to match the camshaft.
__________________
333rwhp 357rwtq
Old 02-09-2008, 10:03 PM   #6
warggod
you see i already bought the cam and installed it summit told me i could run this on a stock motor shouldnt be a problem they said as long as i dont go to big i should be fine
Old 02-09-2008, 10:05 PM   #7
warggod
now i gess im stuck with out a car for now till i get some rollor rockers and shimms i was told from auto parts store they said thats what ford was recommending
Old 02-09-2008, 10:08 PM   #8
charlesm489
get new heads ...afr's
charlesm489 is offline   Reply With Quote
Old 02-09-2008, 10:10 PM   #9
92GreyGT
I think what Summit was saying was you can use that cam with stock heads and short block without piston to valve clearance issues. If you call them back they will tell you valve springs and rockerswill have to be changed if nothing else
__________________
333rwhp 357rwtq
Old 02-09-2008, 10:14 PM   #10
92GreyGT
I know you don't have a Trick Flow cam but this spring kit will work with this cam, everything is included and they are for stock heads. I used this on a set of E7TE heads and the Trick Flow stage one cam and didn't have a problem.
http://www.trickflow.com/partdetail....p;autoview=sku
__________________
333rwhp 357rwtq
165, 172, 303, 90, afr, cam, e303, ford, length, mustang, pushrod, rockers, springs, timing, valve
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
