Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-24-2008, 02:59 PM   #1
djh1121
Send a message via Yahoo to djh1121
Default AOD to T5 swap (wire question)
If you don't have the T5 harning, what wires/what do you need to do to trick it to crank?
__________________
1990 Mustang GT
nothing special
djh1121 is offline   Reply With Quote
Old 02-24-2008, 03:53 PM   #2
94Yellow50
1994 Ford Mustang
Vehicle: 1994 Ford Mustang GT Coupe
Send a message via Yahoo to 94Yellow50
Default RE: AOD to T5 swap (wire question)
for both that ive done:
there is the range sensor that is mounted on the aod that has a big (white?) i think..plug connected to it...if u make sure its in park/neutral, leave it connected, and mount to the t5, it will crank ...but it will crank without the clutch depressed...so remember that..
__________________
GT40 intake, BBK unequal shorties, o/r H, Dumped 44s, 5spd swap, MGW shifter
3.73 gear, 4cyl/H&R SS springs, KYB struts/shocks
www.cardomain.com/ride/2418660
94Yellow50 is offline   Reply With Quote
Old 02-24-2008, 09:08 PM   #3
djh1121
Alright, what have I not done on the wiring? I don't have the t5 wiring hardness, but that should not matter should it? Or do I have to hook something together because of that?
I believe I don't have something hooked up right on the neutral safety switch. Must have missed that step. It want start, so it has to be the neutral switch?
__________________
1990 Mustang GT
nothing special
Old 02-24-2008, 09:13 PM   #4
94Yellow50
1994 Ford Mustang
shouldnt matter no..i kept the stock automatic one...i coulda switched to the t5 cuz the guy gave me it..but then i woulda had to hook up the switch...so i just kept the auto one...do u have that range sensor hooked up underneath?..and are u sure its either in neutral/park...theres a slot...and the part that turns has to line up slot to slot..thats neutral...
__________________
Old 02-24-2008, 09:18 PM   #5
djh1121
I'm lost... do you have a pic?
I did hook the 2 plugs to the pedal but that was it. Did I miss something else?
These are the 2 I hooked up.
__________________
1990 Mustang GT
nothing special
Old 02-24-2008, 09:19 PM   #6
djh1121
and what do you mean "and are u sure its either in neutral/park"????
__________________
1990 Mustang GT
nothing special
Old 02-24-2008, 09:25 PM   #7
94Yellow50
1994 Ford Mustang
ahh..ya see when i did both mine n my buddies we left those unplugged...he actually didnt get the plugs/wires with his anyway...but the neutral/park thing im talkin about is underneat the car ...when u dropped the aod...the shifter cable that came down from the shifter n hooked to the trans...it was connected to a plastic piece with a plugin from the harness to it...once we had the cable unbolted...we removed this plastic module(ranger sensor) and kept it plugged into the harness...this in turn fooled the car into thinking the auto(thats not there anymore but it doesnt know it) was in park/ neutral...thus completely the starter circuit when u went to start it...only thing is you can start it with clutch not depressed because those two switchs u hooked up were not there on ours...so un plug those two u hooked up...and hook up that range sensor with it slot to slot..and it will start
__________________
Old 02-24-2008, 09:28 PM   #8
stang8689
are you talking about the netural safety switch?
__________________
89 2.3 Turbo, 82 T-Top Notch 5.0, 86 LX T-Top 5.0 roller and 86 GT Black in and out with Gt 40X Heads, Smoothed Engine Bay, Battery in Trunk, SLP's, Bolt-on's
stang8689 is offline   Reply With Quote
Old 02-24-2008, 09:34 PM   #9
djh1121
Dang I know you are trying to help me out,but I still can not picture what you are telling me to do...
Are you talking about the 4 wires (on the AOD) and 2 wires (on the t5)?
(I'm a pic person)
__________________
1990 Mustang GT
nothing special
Old 02-24-2008, 09:35 PM   #10
djh1121
I know the problem is the car does not think it's in netural so this is why it will not even turn over.
__________________
1990 Mustang GT
nothing special
50, aod, mustang, swap, t5
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
