Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-09-2008, 02:48 PM   #1
66blownmustang66
Send a message via AIM to 66blownmustang66
Default aod to t5 swap
1992 mustang lx 2 door coupe ;]
the aod went out finally i can put a 5 speed in it.
questions.
i need new flywheel, clutch break assembly, t5 trans, clutch cable kit, anything else anyone can think of??
66blownmustang66 is offline   Reply With Quote
Old 04-09-2008, 04:27 PM   #2
projectresto83
projectresto83's Avatar
Vehicle: 83 GLX, 93 LX, 98 sixer
Default RE: aod to t5 swap
You need to use the search button to find some more information. But while I am here, flywheel, clutch assembly (with pilot bearing), trans with bellhousing, 3 quarts of tranny fluid, cable kit, clutch peddle assmebly, and the shifter. That is all I can think of. If anyone else knows something I missed chime in.
__________________
Off building sand castles in the middle east
projectresto83 is offline   Reply With Quote
Old 04-09-2008, 05:42 PM   #3
Toomstone
q Starter index plate
q Bell housing/scatter shield
q Pivot ball
q T5/T5Z transmission
q Shifter
q Shifter knob
q Shifter weather seal
q Shifter boot
q Flywheel
q Clutch kit (pressure plate, clutch disc, and throw out bearing)
q Pilot bearing
q Clutch fork
q Clutch cable
q Clutch cable clip (secures the cable to the bell housing)
q Pedal Assembly
q Clutch quadrant
q Speedometer gear
q Back-up light harness (Ford part# E7ZZ-15525-A)
q T5 transmission cross member
q Exhaust hanger
q Bolts:
Upper bell housing bolts (or washers to make up the extra length)
Pressure plate bolts
Starter plate to bell housing bolts
Transmission to bell housing bolts
Toomstone is offline   Reply With Quote
Old 04-09-2008, 06:13 PM   #4
steele901
steele901's Avatar
Vehicle: Beater
http://www.fordmuscle.com/archives/2000/09/t5swap/
__________________
'95 GT 5-Speed - 276rwhp & 321rwtq(Gone but not forgotten)
steele901 is offline   Reply With Quote
Old 04-09-2008, 06:20 PM   #5
stang8689
My advise is to buy a new clutch fork and pivot ball, only about $50. Adjustable clutch cable is a must for sticks
__________________
89 2.3 Turbo, 82 T-Top Notch 5.0, 86 LX T-Top 5.0 roller and 86 GT Black in and out with Gt 40X Heads, Smoothed Engine Bay, Battery in Trunk, SLP's, Bolt-on's
stang8689 is offline   Reply With Quote
Old 04-09-2008, 07:04 PM   #6
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
check ebay for someone selling a complete set up
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 04-11-2008, 07:04 PM   #7
LongrodLX
auto is faster
LongrodLX is offline   Reply With Quote
Old 04-11-2008, 07:11 PM   #8
mjr46
mjr46's Avatar
Vehicle: 85 mustang
Quote:
ORIGINAL: LongrodLX
auto is faster
and stick is more fun!!!
__________________
15525, 351, 92, aod, bellhousing, bolts, e7zz, e7zz15525a, faster, ford, kit, length, mustang, part, parts, sale, size, swap, t5
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
