not tryin to steal the thread but redpony do those springs work with the stock retainers and everything?
yes, they should work fine.
Quote:
ORIGINAL:1995mustang818
ok then so new springs......any suggestions besides the e cam i kinda like the e cam but im ganna be putting a unit on the car so i would want some thing to work good on and off the unit
like i said the tfs is a awesome cam, and if tfs makes a spray kit, they would want you to buy their products, so they'd make them work with eachother. i'm getting ready to build a new motor for my 95 and i'm going to run the tfs top end and the tfs spray kit on a stroker motor. i trust tfs and their cams on and off the bottle
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
1983 Black GT- Sold
1988 Red GT-Sold
1995 Black GT - Cobra Front Brakes, 306, TFS 1 Cam, Eddy RPM Heads, Eddy RPM 2 Intake, 3.55 gears
1983 MERCURY CAPRI V6 "Uh-Oh Oreo"
the f cam respond really well with nitrous. is has a 512 lift and 226 duration. is more lopey than e cam as well. doesnt really make power until about 2800-3000rpms though, it is best when used with a power adder such as n20 or supercharging
__________________
Mods: 3.73 gears,superchip,underdrive pullies, k&n filter, mac o/r h pipe, original flows dumped, weld wheels, 4inch cowl hood,B&M shiftkit.
gt-40 heads with up graded springs
tfs stg 1 cam maybe some thing a little bigger
93' cobra manifold
24lbs with matching mass air maybe 30lbs because of the nitrous all ready have 6 of them of a super coupe
65mm throttle body
snyper nitrous kit with a foggermade by N.O.S maybe a 100 shot 125shot
255 walbro fuel pump
gears 4.10
suspension drag lauch kit with air bag
90/10 struts
50/50 shocks
sub frame connectors
later in the future tubular k-member
__________________
1990 5.0 5 speed,93'cobra intake manifold, gt-40 heads, k&n filter,lond tube bbks x piped flowmaster 40s , crank pulley a/c delete smog pump delete.
lakewood 90/10s and 50/50s in the back eibach drag lauch springs upper and lower control arms 4.10s sub frames
go to andersonfordmotorsport.com and check out their cams...im going to be getting a b-31 when i s/c the car soon....i heard nothing but awsome things about their cams..
__________________
308 C.I.D....under major construction with some boost waitin
93' cobra manifold
65mm throttle body
gears 4.10
90/10 struts
50/50 shocks
sounds like it'll make a good setup
__________________
1983 Black GT- Sold
1988 Red GT-Sold
all their hydrualic rooler cams are 299$ i belive....not bad for what i seen some other hydrualic roller cams going for...try and stay away from alphabet cams they are old technology..i know anderson...lunati...comp cams make good stuff
__________________
