Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-28-2008, 12:26 PM   #1
pfs4life
Send a message via AIM to pfs4life
Default 2.3 to 5.0 swap
ive got a 302 ive built to go in my 93 2.3 hatch i plan on puttin a t5 behind it
so what will i have to put in the mustang to make it fit
im putting an 8.8 in with 3 73 but will i need a new tranny cross member and k member?
__________________
'93 mustang lx 2.3 (shelby)
pfs4life is offline   Reply With Quote
Old 09-28-2008, 12:52 PM   #2
taurus gt man
Vehicle: 89 lx mustang
Same body for both, k-member is fine but motor mounts need to be changed as well as tranny crossmember. New wiring harness and from what I hear underdash harness as well for the gauges to work. Fuel lines need to be changed or rerouted and the stock rear can be used but wont last forever under that motor. Also t5 should be from a 5.0 or equivalent or it wont last too long. Driveshaft will probably need to be changed I was told just the yoke but ended up replacing it. Im on the second year of my swap due to school, work, military, and finances. Chris
__________________
You can run but you cant hide because in your time of fear your heartbeat will be there for me to hear and ill track you down and pass you up then make you feel just like a dunce.
taurus gt man is offline   Reply With Quote
Old 09-28-2008, 01:02 PM   #3
calfroper_06
calfroper_06's Avatar
proply get a new radiator and your 4cyl tack wont work with the 5.0 either
__________________
88 gt...17" cobras, cammed 306
calfroper_06 is offline   Reply With Quote
Old 09-28-2008, 01:59 PM   #4
pfs4life
well i plan on a new rear and radiator like a 2 or 3 core something nice and big but if i dont need a new k member thats sweeet it will make it alot easier i got to convert it to stick and i plan on getting a cluster out of a 89-93 lx or gt
__________________
Old 09-28-2008, 02:39 PM   #5
timspony
SVT Section Moderator
timspony's Avatar
Vehicle: 03 & 04 SVT Cobra
302 will drop right in on a 4cyl. ....EFI or a carb. setup?
__________________
2003 SVT Cobra, DSG #7248 of 8394, Bassani Catted X, Flowmasters, JLT CAI, 2.76 BF Pulley, AFCO HE, PFab Tanks, SCT Xcal2, Pro 5.0, BF IRS Brace, Nitto 315 DR's...465 rwhp, 456 rwtq - Tuned by Mustang Magic!
2004 SVT Cobra, TR #269 of 1896 RagTop...Not Stock!
timspony is offline   Reply With Quote
Old 09-28-2008, 06:26 PM   #6
chazmcgee
im in the final stages of this. K members the same motor mounts need to be 5.0 and my transmission bolted right up to the stock ****. Im carbed no wiring harness for me right now i only have like 10 wires and thats everything, lights not ran yet. Alls i have left is running the tranny cooler lines, buying a shifter cable and ill be on the street in the daytime lol. oyea need to drain my breaks. PM me if you need any pointers i ran through this with no problems just been kinda lazy.
chazmcgee is offline   Reply With Quote
Old 09-28-2008, 06:27 PM   #7
chazmcgee
Making it EFI on the other hand idk i didnt want to deal with that
Old 09-28-2008, 08:14 PM   #8
stanguy306
1993 Ford Ranger
stanguy306's Avatar
You will need the motor harness and ecu from that motor...I think the inside harness is the same....and you will HAVE to run a GT or LX cluster for everything to work properly.
__________________
82 Mercury Capri EFI 5.0 bone stock.
87 White Notch all Orig.
93 Prerunner Ranger 302 swap, C4, eddy heads/Intake, F cam, . Tube chassis. 4-linked. 250hp/270rwtq
stanguy306 is offline   Reply With Quote
Old 10-05-2008, 05:26 PM   #9
pfs4life
well i got the harness and ecu out of the thunderbird along with the tranny crossmember which i think is a double hump.
__________________
Old 10-06-2008, 01:06 AM   #10
Chadwick86
Chadwick86's Avatar
Vehicle: 1983 Mustang L
check your tach, it might have the little screw on it to change from 4-6-8. Mine did, but she's an '83. Who knows, just throwing shyt out there, good luck on the build!
__________________
1983 Mustang L
- '85 5.0 HO (.30 over, fresh rebuild)
- E7 Heads
- Stock crank, cam, and carb
- C4 Trans
- 8.8 w/4.10's & Moser C-clip eliminators
- Full exhaust
Quote:
Originally Posted by Shelty View Post
its always a bit unnerving tho, she is mah baby... not even a girl could take her away from me... lol
Chadwick86 is offline   Reply With Quote
23, 50, 93, carb, harness, mustang, swap, wiring
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
