hey guys i have a few questions. i have a 347 stroker 9:5:1 compression with twisted wedge heads i believe they are 195s afm b31 blower cam and a efi spyder intake manifold. as of now its sittin at college waiting to be put together. what puzzles me is that i have stock injectors fuel rails stock t/b and maf sensor. now the b31 cam requires no less than 30 pound injectors and a 80 mm mass air and 373 or 355 rear gears i have stock 3.08's but have ford racing 4.10s boxed at my house, i was researching around and seen that. would this spyder intake work well for heads and cam combo i have? i know its mainly used to superchargers but as of right now i cannot come up with the cash for a s/c. And how bad would my stock parts choke the motor if i have stock injectors, maf, fuel rails, t/b etc etc.? Im considering selling the spyder intake for something else but if it works with the setup i have for now i would like to keep it. any suggestions would help ive been told there will be torque loss because of such a big intake (90 mm) on a naturally aspirated motor, and then again ive heard it will run fine. any suggestions would help. thanks.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
90 mustang gt bbk headers bbk o/r H pipe flows. king cobra clutch
A Real work in progress. and a everyday daily driver. beater anyone?
i have one on a n/a 331. they work fine for n/a and are awsome for boost.
__________________
95gt, 331, canfield 195's, canfield efi intake; efi spyder elbow, ci cam, 90mm accufab TB, 1 3/4 accufab LT's, 3in accufab h pipe, 3in magnapacks, 4.30's, solid bushing rear upper/lower team z suspension, team z tubular k member and A arms, front coil overs with strange 10 way all the way around. currently aode; going to tko600.
For Sale:
aode,clutches,modified VB,3500 stall,28oz or stock flexplate, any thing needed for swap.
$1600 for trans, converter, and flex plate.
i had a rpm2 intake... i sold it...bought the vic jr efi...
__________________
For Sale:
if you dont have new injectors, go buy like 52's. im dead serious, that will be more than enough for a n/a and good for a boosted setup. wont have to buy 2 sets.
im almost done with mine, i got school and work full time so i never have time for the car. i keep buying new stuff for it, but havent got everything on it. im waiting for cc plated so i can finish the front end, got some welding on the tq boxes then the rear goes back in w/ the new susp, and then finish the few things on the motor and im ready to rock until i do the 5 speed swap lol
__________________
For Sale:
and your gonna use stock injectors, and all that on your built 347 , i wouldnt that thing would run way to lean..
for the time being yes. but im looking around for a set of injectors and a mass air flow to go with it. i found a bbk throttle body im probably going to buy it tomrrow. its too bad i dont have a beater. my stangs my daily driver tonight it was snowing here in cumberland maryland, im not so sure i wanna drive this through the winter again like i did last year lol. the fuel rails for that intake look like they sit higher or bolt higher to it compared to my stock plenum. do i have to make any modifications to make it fit? and a friend of mine told me he had problems gettin his stock injectors to fit but eventually got em but had problems installing them. should i have any problems? appreciate the help guys, this clears up some questions i had.
__________________
baby the car if your running the stock injectors still
and dude dont drive that thing in the snow with that motor
stop buying parts and buy a winter car/beater so u can drive that in the snow/winter instead of the stang
I found a tracker in good running condition 100 bucks 4x4 needs lots of body work but who cares that just means i can beat it more lol. i have the option of takin a family members jeep but im not sure about all the time tho.
__________________
the rpm2 can use the stock rails and all that with no problem...
the vic jr needs either new fuel rails, or a longer hose for the front and rear fuel rails, the stock length crossover hose is too short...and brackets have to be made to hold the rails down...
__________________
For Sale:
