Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 12-16-2008, 06:59 PM   #1
mustangmike33
1990 Ford Mustang
Vehicle: 1990 Ford Mustang
Default Turn Signals
hey guys, ive had my car for about 6 years now. dont ask me why i havent already fixed this problem, but anyway, my turn signals havent worked since ive had the car. i have replaced all the bulbs, checked all the fuses, replaced the flasher, and have even switched out the turn signal handle assembly. still nothing works. the windsheild wipers work perfect, except for the windsheild cleaner. when you push the knob in nothing happens, but i have recently took all that out of the car. but my turn sugnals are bothering me, any help would be greatly appreciated.
mustangmike33 is offline   Reply With Quote
Old 12-16-2008, 08:11 PM   #2
timspony
SVT Section Moderator
timspony's Avatar
Vehicle: 03 & 04 SVT Cobra
I just replaced the turn signal lever on my daughters 91 GT...takes about 10 mins. to change & solved her problem!...they go by the years '87-89 & '89-93 (air bag) for those year Fox's...Everything now works!
The lever should cost around $150 to your door!
__________________
2003 SVT Cobra, DSG #7248 of 8394, Bassani Catted X, Flowmasters, JLT CAI, 2.76 BF Pulley, AFCO HE, PFab Tanks, SCT Xcal2, Pro 5.0, BF IRS Brace, Nitto 315 DR's...465 rwhp, 456 rwtq - Tuned by Mustang Magic!
2004 SVT Cobra, TR #269 of 1896 RagTop...Not Stock!
timspony is offline   Reply With Quote
Old 12-23-2008, 07:43 PM   #3
FoxGT
Vehicle: unicycle
Send a message via AIM to FoxGT
Where was the flasher you replaced located? Do your hazards work?
__________________
If you have to ask what it takes to get to 500 HP, you don't have what it takes to get there.
'89 Mustang GT
'86 Mustang vert
'84 TT 351w notch
'89 Turbo Ranger
'96 Musta
FoxGT is offline   Reply With Quote
Old 12-23-2008, 07:51 PM   #4
FORD TOUGH
1994 Ford Mustang
FORD TOUGH's Avatar
Vehicle: 1994 Mustang GT
It sounds like the multifunction switch but you say replaced it. Can you hear the flasher? If so what does it sound like ? fast or slow? When you use the turn signal does the indicators in the dash work?
FORD TOUGH is offline   Reply With Quote
Old 12-23-2008, 08:26 PM   #5
calfroper_06
calfroper_06's Avatar
i had the exact same problem with mine, the brights work and so did the wipers but no turns signals. replaced bulbs, both flashers,(ones under the dash around the column on mine, and the others in the fuse panel). I check for power coming to the turnsignals and it was getting there just was coming out the other side when on.
So i broke down and bought one off ebay for like 125 or so and put it in and still nothing, similiar to you. What happen was someone hooked the powerwire coming into connector in the wrong little hole. i looked and the taps coming out of the turnswitch and stuck the wire in the connector to go on the correct tab, and now it works like new. i probly wasted a 120 bucks on a new switch but now i can read everything on it
__________________
88 gt...17" cobras, cammed 306
calfroper_06 is offline   Reply With Quote
Old 12-24-2008, 12:24 AM   #6
Tberg725
1988 Ford Mustang
Tberg725's Avatar
Vehicle: 1988 Ford Mustang
Send a message via AIM to Tberg725
Lol mine havent worked since I put the car away too lazy to deal with it hazzards work though!
__________________
Tberg725 is offline   Reply With Quote
Old 12-24-2008, 03:14 PM   #7
holyshift
holyshift's Avatar
Had the same issue awhile back, come to find out the plug that goes onto your ignition switch apparently must give power to your turn signals, cause mine quit working out of no were so i tore my steering column apart and start shaking wires, and i found that plug loose and they turn on....so check it out once...see what ya find.
__________________
88 Hatch Stock Bottom End 302,GT40 Turbo Swirls,Crane Cam, 1.7 rockers,ud pulleys,Holley Blue,16 gallon cell,Edelbrock Performer Intake,650 Holley DP,C4 with TCI goods, Art Carr 3500 Stall,Skinnies,slicks,Best ET 12.43 @ 108 (with 5 speed) Back in 12.90's with C4.
Yea Dude
Racing
holyshift is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
