Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-23-2009, 02:30 PM   #1
vogs77
vogs77's Avatar
Default This cam recomended by comp cams, any ever use this?
I talked to comp cams today for a cam recomendation, this is what they came up with
Xtreme Energy™, XE270HR
RPM-Range 1800 to 5800
Valve Timing 0.006
Lobe-Center Angle: 114
Intake Centerline 110
intake exhaust
Duration: 270 276
Duration @ .050" Lift 218 224
Valve Lift 0.512 0.512
Lobe Lift: 0.321 0.321
http://www.compcams.com/Cam_Specs/Ca...csid=1054&sb=2
I will be installing GT40 iron heads with 1.6 roller rockers, cobra upper and lower, and larger injectors and mass air. Does this sound like a good cam for my car?? Has anyone ever used this one with in their car?
__________________
1986 GT, Vortec Supercharged, 3:55, 5spd., BBK Long Tubes and H Pipe into Flowmasters, MSD, Mass Air, Accel Coil, Subframe Connectors, BBK Upper and Lower Rear Control Arms, Hurst Short Throw, Tahesian Red Sunset Paint, 23000 miles, Runs Strong!
vogs77 is offline   Reply With Quote
Old 01-23-2009, 03:21 PM   #2
FivePointOhh
FivePointOhh's Avatar
Vehicle: 1989 Ford Mustang
its a very good cam, im getting the same one. i know many people who run it and like it.
__________________
I <3 my '89 LX 5.0 + MustangForums.com
FivePointOhh is offline   Reply With Quote
Old 01-23-2009, 11:58 PM   #3
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
I've seen a few people run it and have decent results
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 01-24-2009, 11:11 AM   #4
stanguy306
1993 Ford Ranger
stanguy306's Avatar
+1 its a good cam and you just slam it in line up dot to dot no degreeing etc.
__________________
82 Mercury Capri EFI 5.0 bone stock.
87 White Notch all Orig.
93 Prerunner Ranger 302 swap, C4, eddy heads/Intake, F cam, . Tube chassis. 4-linked. 250hp/270rwtq
stanguy306 is offline   Reply With Quote
Old 01-24-2009, 01:55 PM   #5
vogs77
vogs77's Avatar
Thanks for the input, there are too many cams to choose from out there. It is hard to pick the right one. Not going with a custom grind, just looking for a good street performing cam.
__________________
Old 01-24-2009, 05:32 PM   #6
94StinkinLincoln
94StinkinLincoln's Avatar
Vehicle: 1995 mustang gt
Send a message via Yahoo to 94StinkinLincoln
did u get my pm back?
__________________
95gt, 331, canfield 195's, canfield efi intake; efi spyder elbow, ci cam, 90mm accufab TB, 1 3/4 accufab LT's, 3in accufab h pipe, 3in magnapacks, 4.30's, solid bushing rear upper/lower team z suspension, team z tubular k member and A arms, front coil overs with strange 10 way all the way around. currently aode; going to tko600.
For Sale:
aode,clutches,modified VB,3500 stall,28oz or stock flexplate, any thing needed for swap.
$1600 for trans, converter, and flex plate.
94StinkinLincoln is offline   Reply With Quote
Old 01-24-2009, 07:34 PM   #7
mjr46
mjr46's Avatar
Vehicle: 85 mustang
Quote:
Quote:
...I know buy stinkinlincolns xe270 cam
__________________
Old 01-24-2009, 07:36 PM   #8
94StinkinLincoln
well mjr, i guess you dont need my password to view my pm's. so nice of you, thanks.
__________________
For Sale:
Old 01-24-2009, 07:41 PM   #9
mjr46
mjr46's Avatar
Vehicle: 85 mustang
I don't need your password...lol...you freely volunteered the info....YOUR SIG!!!......but if I were him I'd buy it........just tryin' to help you out...hevean knows it's a task to sell all your parts when you redo a combo, I have a whole pile on my bench right now, as I did just what you did....= reconfigured
__________________
Old 01-24-2009, 07:42 PM   #10
94StinkinLincoln
well i forgot about having that in my sig, my apologies to you.
__________________
For Sale:
03, 327, 50, blank, cam, cams, cobra, combo, comp, custom, degreeing, forum, grind, mustang, sound, xe270, xe270hr
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
