Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-01-2009, 02:44 AM   #1
lx5.0
1992 Ford Mustang
lx5.0's Avatar
Vehicle: 1992 mustang lx vert
Default maf screen
will anything happen if you remove screen that is in front of maf
__________________
1992 lx convertible
lx5.0 is offline   Reply With Quote
Old 02-01-2009, 06:10 AM   #2
302army187
1989 Ford Mustang
302army187's Avatar
Vehicle: 89 mustang lx 'vert
no.
removed mine when i cleaned my MAF when i first got my car.
some magazine tested it, and you gain like 88CFM removing the screen.
__________________
302; Cobra T5, 4.10's, ported E7's, Typhoon intake, full bolton's, full exhaust, NX 100-150wet shot
UPR upper/lower control arms, MM full length subframes, Strange Engineering 10way Shocks & Struts
Mods on the way: Ported&O-Ringed Trick Flow heads, TF stage 2 cam, a/c removal, battery relocation
Thanks for the sig' Xeno!
302army187 is offline   Reply With Quote
Old 02-01-2009, 08:37 AM   #3
steel1
1993 Ford Mustang
steel1's Avatar
I upgraded my maf to a 70mm from a 95 and they have no screen, so it shouldn't matter.
steel1 is offline   Reply With Quote
Old 02-01-2009, 07:18 PM   #4
Shelty
1991 Ford Mustang
Shelty's Avatar
Vehicle: '91 5.0 LX 'vert
Send a message via AIM to Shelty
there is a screen on the maf? i has none
__________________
'91 5.0 5-speed
full O/R exhaust, Ram Air Intake,pullies, full length SF connectors, CF DF clutch, tri-ax, aluminum drive shaft, 3:73s, slotted rotors, strange 10 ways, exterior mods/ some interior billet bling
soon...more suspension work i.e. control arms, springs, ball joints, bushings etc in due time (Imma broke college lad)
Shelty is offline   Reply With Quote
Old 02-01-2009, 09:07 PM   #5
luckythirteen13
luckythirteen13's Avatar
cutting out the screen is an old school way of adding hp. they did it before there was a large selection of aftermarket mafs
__________________
7.25 @ 95.17MPH with a 1.70 60' on street tires and low boost-untuned and never been on the dyno
TWIN TURBO!! Keep drooling, I'm spooling
luckythirteen13 is offline   Reply With Quote
Old 02-01-2009, 11:37 PM   #6
dudeboy
Vehicle: 1990
The screen is used to 'straighten' the airflow before the sensor.
Removing the screen will introduce error into the MAF output calibration.
good luck,
__________________
My name is jason
Formerly known here as 'vristang'
SeattleBlueOvals.com
dudeboy is offline   Reply With Quote
Old 02-02-2009, 12:20 AM   #7
lx5.0
1992 Ford Mustang
lx5.0's Avatar
i read in other threads that only on newer mustangs that screen in used to straighten' the airflow and on the old ones it was just there to stop big debris
__________________
1992 lx convertible
Old 02-02-2009, 12:26 AM   #8
dudeboy
Vehicle: 1990
Quote:
Where did you read this?
__________________
My name is jason
Old 02-02-2009, 12:28 AM   #9
dudeboy
Vehicle: 1990
On second thought... I don't care.
At least not enough to get into a pissing match over it...
If you believe it's there to stop large debris that magically gets past the air filter, then good for you.
I'm done.
good luck,
__________________
My name is jason
Old 02-02-2009, 05:47 AM   #10
302army187
1989 Ford Mustang
302army187's Avatar
funny.
i had a sort of surging issue, cleaned my MAF, REMOVED THE SCREEN, cleaned IAC, and replaced O2, and it WENT AWAY.
no issues sence then, that was a year ago.....
__________________
50, 94, 95, function, maf, mustang, noise, price, r, remove, removing, screen, screens, sensorscreen
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
