Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-06-2009, 04:10 AM   #11
302army187
1989 Ford Mustang
302army187's Avatar
Vehicle: 89 mustang lx 'vert
in a '96 exploder?
what else is done to the truck?
i use to the have a '97 4.0 when i was in the army and beat that thing to death, by far the worst ive ever been on a vehicle, and it took it for 6mth's before i got rid of it.
kinda wish i had one. but i have a 1996 Bronco 5.0 now, just wish it was a lil quicker.
__________________
302; Cobra T5, 4.10's, ported E7's, Typhoon intake, full bolton's, full exhaust, NX 100-150wet shot
UPR upper/lower control arms, MM full length subframes, Strange Engineering 10way Shocks & Struts
Mods on the way: Ported&O-Ringed Trick Flow heads, TF stage 2 cam, a/c removal, battery relocation
Thanks for the sig' Xeno!
302army187 is offline   Reply With Quote
Old 02-06-2009, 06:02 AM   #12
Portmaster
Banned
Vehicle: 1985 LX Coupe
With all the money you have it now it's not the time to go cheap or get rushed. Buy the correct retainers
Portmaster is offline   Reply With Quote
Old 02-06-2009, 09:41 AM   #13
F150 StrokerCobra
Quote:
Originally Posted by 302army187 View Post
in a '96 exploder?
i worked at the local ford dealer summer job
the engine was for an 1996 Explorer v8 under warrenty
but the owners tottalled the vehicle before the dealership had chance to change the engine so it sat there for 4 years then i got a god deal and bought it
yeah i know i dont wanna go cheap now that im this far
__________________
--==Jurgen==--
Under Construction: 1989 F150 reg cab longbed
5.0 HO, Comp custom cam 0.18/0.24 @0.50 0.513Lift , Flowtech LT's, hooker aero chambers, GT40 heads, Edelbrock Air Gap Performer intake, Holley 650dp Carb,
F150 StrokerCobra is offline   Reply With Quote
Old 02-06-2009, 09:47 AM   #14
FivePointOhh
FivePointOhh's Avatar
Vehicle: 1989 Ford Mustang
hey strokercobra...just to rub it in a little bit i ordered some goodies yeterday for a the new cam im getting. i got double springs, valve seals, valve locks and the RETAINERS
plus a few other goodies too
__________________
I <3 my '89 LX 5.0 + MustangForums.com
FivePointOhh is offline   Reply With Quote
Old 02-06-2009, 11:10 AM   #15
F150 StrokerCobra
there youu gooo.. now send some RETAINERS my way as an late christmas gift haha..
ohhohh i forgot... i dont need valve seals becuase my engine is BRAND NEW haha!
what cam did you got?
__________________
--==Jurgen==--
Old 02-06-2009, 11:27 AM   #16
FivePointOhh
your heads come with new seals? you do know that double springs do require a smaller diameter seal right?
comp xe270 .512/.512
im ditchin the b cam
__________________
Old 02-06-2009, 12:10 PM   #17
F150 StrokerCobra
heads are new.. engine has never been started. yet
uhh what do you mean ?never heard of that..about the seals
your messing with me right? lol.. i just cheked and summit doesnt recomend any valve seals with the new valve springs/ locks/ retainers
the cam almost the same as mine
__________________
--==Jurgen==--
Old 02-06-2009, 12:26 PM   #18
FivePointOhh
http://store.summitracing.com/partde...art=CCA-503-16
COMP Cams offers a complete line of valve seals, from the stock GM O-rings to the positive-stop Teflon® seals. These seals are a must to keep unwanted oil from entering the combustion chamber through the clearance in the valve guides. The O-ring seals use the standard retainer and oil splash shield. The umbrella seals are normally used when a larger-than-stock diameter spring is used. In the case of a double spring, the positive stop Teflon® seals are used. For triple-spring applications, use the smaller-diameter Viton® seals.
__________________
Old 02-06-2009, 12:44 PM   #19
F150 StrokerCobra
ohh well.. ill get them too..
those are the ones right?
__________________
--==Jurgen==--
Old 02-06-2009, 01:53 PM   #20
FivePointOhh
to be honest im not 100% sure if they are. but im pretty sure its all the same, rubber umbrella seals are for singles, teflan for doubles and viton for triples. maybe summit tech line could tell you for sure if you told them what springs you bought or someone will chime in and tell you if you need them. i got them with my springs though since it was suggested and ive read a few tiems on here the normal seals dont work with double springs.
__________________
1989, 353518, 50, arm, cam, cams, comp, exploded, explorer, f150, locks, rocker, spring, stock, view
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
