New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-05-2009, 08:22 PM   #1
F150 StrokerCobra
Default DANG!! i ordered cam / springs / locks but forgot retainers.. can i use stock ones?
dont worry about them being worn becuase its a new reman ford engine..
__________________
--==Jurgen==--
Under Construction: 1989 F150 reg cab longbed
5.0 HO, Comp custom cam 0.18/0.24 @0.50 0.513Lift , Flowtech LT's, hooker aero chambers, GT40 heads, Edelbrock Air Gap Performer intake, Holley 650dp Carb,
F150 StrokerCobra is offline   Reply With Quote
Old 02-05-2009, 09:21 PM   #2
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
what springs and for what cam did you order the stuff??
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 02-05-2009, 09:43 PM   #3
F150 StrokerCobra
its a custom cam from comp cams
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 218 int./224 exh.
Advertised Intake Duration: 270
Advertised Exhaust Duration: 276
Advertised Duration: 270 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Valve Lift with Factory Rocker Arm Ratio: 0.512 int./0.512 exh. lift
Lobe Separation (degrees): 110
its basicly the 35-351-8 cam with a lower LSA 4 degrees lower
these are the springs i have and locks
http://store.summitracing.com/partde...art=CCA-986-16
http://store.summitracing.com/partde...+&autoview=sku
FYI its an 1996 Explorer 5.0Ho
__________________
--==Jurgen==--
Old 02-05-2009, 11:03 PM   #4
mjr46
mjr46's Avatar
Vehicle: 85 mustang
you need the proper retainers the stock ones are most likely not large enough diameter to mate with the springs
__________________
Old 02-05-2009, 11:03 PM   #5
mjr46
mjr46's Avatar
Vehicle: 85 mustang
just be patient and get the right stuff, now is not the time to be in a hurry , expecially when prepping the valvetrain!!
__________________
Old 02-05-2009, 11:15 PM   #6
F150 StrokerCobra
letsay if they are big enough and sit good.. i can use them?? becuase the new ones looks like the same diameter but just dubbel spring
well ok.. i will better be patient then have the engine explode on me..
__________________
--==Jurgen==--
Old 02-06-2009, 12:01 AM   #7
FivePointOhh
FivePointOhh's Avatar
Vehicle: 1989 Ford Mustang
dont use the stock ones. i have pictures ill post em. the stockers are multi piece design and ive heard that with performace cams + higher spring pressures will cause them to break apart under load
__________________
I <3 my '89 LX 5.0 + MustangForums.com
FivePointOhh is offline   Reply With Quote
Old 02-06-2009, 12:02 AM   #8
FivePointOhh
__________________
Old 02-06-2009, 12:04 AM   #9
mjr46
mjr46's Avatar
Vehicle: 85 mustang
the inner spring sits on a stepped retainer I believe with a dual set up and the stock ones don't have such = don't use them
__________________
Old 02-06-2009, 12:32 AM   #10
F150 StrokerCobra
well ok thanks guys.. i will have to wait a little longer then..
__________________
--==Jurgen==--
1989, 353518, 50, arm, cam, cams, comp, exploded, explorer, f150, locks, rocker, spring, stock, view
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
