Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-28-2009, 09:45 AM   #1
aode08
Default Fault in YOUR 5.0 ?IAT/ACT Intake Air Temperature/Air Charge Temperature Sensor
Bringing my car back for a weird power and RPM loss when warm that has occurred every since I owned the car, the tuner discovered the IAT/ACT was reading WAY WARMER Air than it should be,
/ being located in the stock position intake manifold.
It has been relocated Yesterday to the CAI Pipe away from the engine and reads the same as the outside air temp now.
Any feedback on this?, my car pulls alot better and feels different cold and hot, same sensor different location.
__________________
347 10:1 , CompCam Custom Grind,Twisted Wedge Heads,Track Heat Intake, 3500 true Stall,4:10's, CAI. 405 HP , 374 Lbs Trq @5,623.4 rpmz
Diablo Tune
aode08 is offline   Reply With Quote
Old 03-01-2009, 09:19 AM   #2
aode08
When you guys relocate, the sensor, its best before the MAF,.
__________________
Diablo Tune
Old 03-18-2009, 01:09 AM   #3
5.0GUY47
Vehicle: 1992 5.0 GT 40
HEY HOW DO YOU DO THIS/
I have a mac cold air intake, it not easy as a rubber intake(factory)
5.0GUY47 is offline   Reply With Quote
Old 03-18-2009, 01:22 AM   #4
aode08
Thumbs up
HERE IS THE EASY WAY FOR ALL.
1.If you have a factory rubber intake tube, buy a new ambient air temperature aka air charge sensor.
2.Take a 1/2 extension, heat it, use it to make a hole BEFORE THE MAF, NEAR THE FRONT HEADLIGHT(AWAY FROM HOT HEADERS).
3. Extend the sensor's wiring, screw in the hole, no sealant needed.
COLD AIR INTAKE(METAL INTAKE TUBE)
-Drill a hole, with a drillbit of 1/2 inch or a little smaller .
-bang the 1/2 extension into the hole making 1/2 hole
-remove shavings and screw the sensor in, no sealant needed.
What happens, the car performs as well hot, as it did cold
Most newer vehicles use this concept, some even put the sensor on the front bumper support(chrysler) ./
Skill Level- Easy
Time 5-15 Mins
__________________
Diablo Tune
Old 03-18-2009, 01:27 AM   #5
aode08
You can leave the old one in the old hole to stay sealed, or buy 1/2 plumbing nut from home depot and screw it in, take the sensor with you if you want to match
the nut is $.78 cent
the sensor $16.00
extend wiring 0.00-$7.00
__________________
Diablo Tune
Old 03-18-2009, 11:20 AM   #6
5.0GUY47
Thumbs up
ok' I am going to try this out when I get the sensor, it had to be ordered.
my old one was FULL OF BLACK GUNK, BUT I USED THE NUT to seal the hole with some teflon around the plumbing nut/
You are very bright putting the sensor here and it makes sense
1.there will be no more gunk on the sensor, messing up
2.there will be an accurate OUTSIDE air temperature reading for the ECM , good find !
Old 03-18-2009, 03:29 PM   #7
lx5.0
1992 Ford Mustang
lx5.0's Avatar
Vehicle: 1992 mustang lx vert
Skill Level- Easy
Time 5-15 Mins
you got any pics
__________________
1992 lx convertible
lx5.0 is offline   Reply With Quote
Old 03-18-2009, 03:59 PM   #8
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
all you did was trick the ecm into putting more fuel into your car... the tuner could have just fattened up your fuel tables a tad and you would have had the same results
the ACT reads temp in the manifold, when an engine runs, it makes heat. Therefor, you inherently get warmer air temps..
And for those of you whom are reading this thread. I would take all of AODE08's advice with a grain of salt... he's supposedly an ASE tech, but when he couldn't get his flexplate bolted on, he enlarged the holes to get it to fit... then wondered why his car was shaking while running.
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 03-18-2009, 05:56 PM   #9
PJC Racing
PJC Racing's Avatar
Vehicle: *
Good post.
__________________
89 LX Coupe: Factory 5.0, common performance and suspension bolt-ons (306 build inprogress)
86 GT: (current 1/4 project) will have primarily Team Z suspension and chassis additions, 408 with nitrous in the works
2003 Mach 1: programer, exhaust, 4.10'
PJC Racing is offline   Reply With Quote
Old 03-18-2009, 06:03 PM   #10
aode08
addermk2 welcome back, still beating folks with that ol helmet of yours in the closet? ehh : )
haven't seen you in a while, that scenario was under the influence of liquor and I was not ASE CERTIFIED that year... AND ADDERMK2, that was the first time I have ever removed an engine, old - at least im honest
sure pics coming now
__________________
Diablo Tune
50, air, body, charge, ford, fox, iat, intake, location, mustang, sensor, sensor50, sn95, temp, temperature
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
