Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-18-2009, 10:38 AM   #1
Redneck1465
Default Explorer GT-40P Camshaft change
I am not to familiar with the particulars of camshafts. I am going to change the cam in my explorer 5.0 before I put it in my 94 mustang because I was told the cam in that motor was pretty crappy. What kind of cam should I get? I am not going to be doing any more real add ons like turbos or anything like that. Just gonna stick with the stock motor with a little bigger cam and such. Is it a roller cam or what excately is in the motor? They said that I should also change something else so that it can handle revving higher but I am not sure what that is. Thanks guys I appreciate all the help.
__________________
William Tatge
Redneck1465 is offline   Reply With Quote
Old 03-18-2009, 11:28 AM   #2
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
steeda #19
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 03-18-2009, 01:02 PM   #3
302army187
1989 Ford Mustang
302army187's Avatar
Vehicle: 89 mustang lx 'vert
you need to also get matching spring's that can keep up with the cam.
__________________
302; Cobra T5, 4.10's, ported E7's, Typhoon intake, full bolton's, full exhaust, NX 100-150wet shot
UPR upper/lower control arms, MM full length subframes, Strange Engineering 10way Shocks & Struts
Mods on the way: Ported&O-Ringed Trick Flow heads, TF stage 2 cam, a/c removal, battery relocation
Thanks for the sig' Xeno!
302army187 is online now   Reply With Quote
Old 03-18-2009, 01:12 PM   #4
sn95_331_GT_ yellow
1995 Ford Mustang
sn95_331_GT_ yellow's Avatar
Vehicle: 1995 Mustang GT
Send a message via AIM to sn95_331_GT_ yellow
+1 on the #19 for your combo.
__________________
Canary Yellow 1995 Mustang GT
had bolt ons: wasnt fast enough, only beat LT1's.
357W build for about 3 weeks (436rwhp 402rwtq) taken out for my Factory Five '33 Hot Rod
baby boy due 20091203, cars kind of on the back burner (he's gonna help build it).
408W carb'd in the works (block and rotating kit already here).
sn95_331_GT_ yellow is offline   Reply With Quote
Old 03-18-2009, 06:08 PM   #5
Redneck1465
What kind of springs should I get??
__________________
William Tatge
Old 03-18-2009, 06:16 PM   #6
PJC Racing
PJC Racing's Avatar
Vehicle: *
Quote:
What the cam calls for.
__________________
89 LX Coupe: Factory 5.0, common performance and suspension bolt-ons (306 build inprogress)
86 GT: (current 1/4 project) will have primarily Team Z suspension and chassis additions, 408 with nitrous in the works
2003 Mach 1: programer, exhaust, 4.10'
PJC Racing is offline   Reply With Quote
Old 03-18-2009, 10:31 PM   #7
83stangglx
Vehicle: 1983 mustang glx
E cam
83stangglx is offline   Reply With Quote
Old 03-18-2009, 10:37 PM   #8
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
I wouldn't waste my time doing a cam swap in an explorer, I doubt you will see any real noticable Hp gain.
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 03-19-2009, 11:50 AM   #9
Redneck1465
Really?? I was told with a good cam you would see a jump from the stock 220 to around 250 or 260. Was I lied to??
__________________
William Tatge
Old 03-19-2009, 12:58 PM   #10
15austin
15austin's Avatar
Vehicle: 88 Ford Mustang GT
Yea, you were lied to. A cam aint going to give you that big a jump in power. I would still get a cam though like that Steeda #19 or TFS stage 1. I think it would be worth it for the loply idle if anything. Especially if you have the engine out of the car.
__________________
88 GT hatch, 306, Notched TRWs, subframes
x303, 1.6 RRs, 3.73s, T-5, AFR 185's,
190lph pump, adj fpr, aluminum driveshaft
performer rpm, 24# injtrs, 4core radiator
70mm t/b, 73mm maf, c/a/i, pulleys
o/r h pipe, shortys, flowmasters, ele fan
UPR u/l control arms, torque box plates
12.6s @112mph 2.0 60ft on street tires
15austin is offline   Reply With Quote
50, camshaft, explorer
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
