Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-18-2009, 06:49 PM   #1
88GTBLKBTY
1988 Ford Mustang
88GTBLKBTY's Avatar
Vehicle: 88,Ford,Mustang GT
Default HELP Headers Glowing Red @ Idle?
Hello, Converted over to maf calibrated for 24#inj from sd rebuilt engine .30 over new pistons stock crank and rods fresh rebuilt e7te heads cold air intake bigger throttle body with edelbrock rpm perf. intake bbk shortie headers and exhaust. I finally put her back together and fired her up on the weekend and while she was sitting there @ idle checking for leaks I noticed the headers GLOWING RED and immediately shut her down. Does anyone know what I should do, or what should I start checking for?
88GTBLKBTY is offline   Reply With Quote
Old 03-18-2009, 06:51 PM   #2
symonds86
Vehicle: 1988 ford mustang GT
check timing
__________________
symonds86 is offline   Reply With Quote
Old 03-18-2009, 08:00 PM   #3
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
cam timing
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is online now   Reply With Quote
Old 03-18-2009, 09:24 PM   #4
.boB
That usually means a lean mixture.
__________________
.boB
'08 V6 Pony
'65 Monster FFR Roadster
.boB is offline   Reply With Quote
Old 03-18-2009, 09:36 PM   #5
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
I'd check the ignition timing and make sure you don't have any vaccum leaks, like at the throttle body or intake
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 03-18-2009, 09:40 PM   #6
artillery129
Vehicle: 1995, Acura, Legend
Timing belt misaligned? ignition at the wrong times sounds like to me, careful could dominate some valves
artillery129 is offline   Reply With Quote
Old 03-18-2009, 09:55 PM   #7
88bluethunder
Vehicle: 1988,Ford,Mustang
I'd check O2 sensors too if everything else checks out... if the sensors are bad they wont relay to the computer that its running lean.. in your case really lean.. whats temp. gauge say??
__________________
[IMG][/IMG]
88 Mustang GT
.040 Bore, GT40P Heads w/ 1.6RR, B-Cam, Edelbrock Intake,70mm T/B, MSD Ignition, A/C Delet Kit,Under Drive Pulleys, Aluminum Radiator, Steeda TRI-AX, Aluminum Flywheel and driveshaft,UPR K-Member Kit w/Coil Overs, 3.73 Gears.
2000 F350 7.3L PSD
10" Lift on 38's
Lockers and 5.13gears F&R
Intake, Exhaust,Guages, and TW Chip
88bluethunder is offline   Reply With Quote
Old 03-18-2009, 09:56 PM   #8
mjr46
mjr46's Avatar
Vehicle: 85 mustang
Quote:
hey this is a mustang forum, not an ACURA forum!! Our rides tain't gots no timing belt!!! dominate valves??? you mean burn some??..either way welcome
__________________
Old 03-18-2009, 11:49 PM   #9
NotchAbove
Vehicle: 1993 Mustang Notchback
Just went through this, your distributor is off, and your timing is retarded.
Do this, loosen slightly the distributor hold down nut, just enough so you can turn the distributor. Now with the car running turn it clockwise, and I bet you the car will start to sound better and the idle with pick up. If so, then it is exactly what I said.
The headers are red because the timing it retarded (late) so raw unburnt fuel is pouring down the headers and turning them red.
Check out this how-to:
http://www.mustangclubofmd.com/phpbb...pic.php?t=2674
NotchAbove is offline   Reply With Quote
Old 03-19-2009, 01:20 AM   #10
5pointslow91
5pointslow91's Avatar
Vehicle: Built Ford Tuff
Send a message via AIM to 5pointslow91
wow thats crazy
__________________
No Rest 4 the Wicked
Quote:
Originally Posted by SKAR View Post
and if I dont
ill be just a bitch
a lonely one.....
5pointslow91 is offline   Reply With Quote
88, glowing, gt40p, headers, heads, idle, ignition, mustang, red, redcom, roller, scorpion, timing, wwwheaders, wwwheaderscom
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
