Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-10-2009, 07:00 PM   #11
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
Quote:
Originally Posted by Portmaster View Post
This is the debate older than dirt. Any kind of synthetic is pretty good. My opinion is the best on the shelf is Royal Purple, Redline, Mobil1, Amsoil and the list goes on. With 150K Id stick with some 10W40.
only you and bernie would know for sure...you were both there when it began!
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 04-10-2009, 08:23 PM   #12
OnyxCobra
OnyxCobra's Avatar
Vehicle: '95 Mustang Cobra
Send a message via AIM to OnyxCobra
I'll honestly say I think Royal Purple is a huge ripoff. I run Supertech synthetic oil and it's great oil for the money.
__________________
CarDomain - OnyxCobra
OnyxCobra is online now   Reply With Quote
Old 04-11-2009, 12:09 AM   #13
JayBanion
1988 Ford Mustang
JayBanion's Avatar
Quote:
Originally Posted by taker52 View Post
do the smoke test on the engine take off the oil camp when the car is cool start up the car and look for smoke if u can use the throttle on the engine to rem it up no more then like 2500 if smoke comes out then the engine is bad usely .
Ok so take the oil cap off... look for smoke out of the exhaust or out of the fill neck?
__________________
F**K THAT FUEL INJECTION S**
88' GT - GT40P's, Comp 986 vavle springs, Comp xe276hr cam, Comp Magnum 1.7 roller rockers, Comp Pushrods, Edelbrock 289 Performer 4bbl intake, Holley 650, BBK Longtubes, BBK shorty o/r H-Pipe, Dumped flowmasters, Ford 9mm wires, Crane PS91 coil, MSD 6A, Ford Racing 4.10 gears, Ford Racing King Cobra clutch, Hurst shifter, Holley Blue Fuel pump, jegs 12 gallon pro-street fuel cell, Holley Regulator, blood sweat and tears
JayBanion is offline   Reply With Quote
Old 04-11-2009, 12:21 AM   #14
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
^^^^^glad that's your opinion and not fact cause truth of the matter is royal crap ranks 8th or 9th on the list on how well it passed all the independent tests it was subjected to such as the 4 ball friction wear test ect ect, mobil one was low on the list too Pennzoil and Amsoil were among the top performers in all aspects such as the quality of detergent packages used as well as all wear tests and shear tests they were subjected to, I have the independent test conducted as a print out somewhere at work
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 04-11-2009, 12:23 AM   #15
mjr46
mjr46's Avatar
Vehicle: 85 mustang
Quote:
I run the regular supertech oil and filter in my 81 vw d/d for the past 100k and the car now has 256k....supertech in a d/d ftw!!! 8 dollar oil change ftw!!!
__________________
Old 04-11-2009, 03:11 AM   #16
5.0stang123
Vehicle: 1990 mustang lx 5.0
Ive been using mobil 1, im doing a oil change soon what oil should i get, or should i stick with mobil 1? Ive never seen redline or amsoil around here so those 2 are out. How is penzoil synthetic and castrol sythetic compared to mobile 1?
__________________
90 mustang 5.0 lx 25th aniv gray(black interior)
Powerslot rotors/hawk pads
Eibach pro kit springs, tokico hp struts/shocks, MM cc plates
Dynomax exhaust, no cats, 3.73 gears
J&M subframes, steeda tri ax
5.0stang123 is offline   Reply With Quote
Old 04-11-2009, 07:27 AM   #17
Portmaster
Banned
Vehicle: 1985 LX Coupe
Quote:
Ive seen all the test results and the fact of the matter is those test don't mean much unless you have some real problems going on inside your engine. I personally run Mobil one in everything. If the engine is built right you could run about anything in it. As far as what goes into your cars engine any of what I mentioned is more than enough. Until they incorperate the 4 ball friction test into my engine I think Mobil1 will do me fine.
Portmaster is offline   Reply With Quote
Old 04-11-2009, 09:22 AM   #18
uedlose
1989 Ford Mustang
uedlose's Avatar
Vehicle: 89 mustang
Walmart oil in my DD (220,000+)and then there synthetic in the wife's DD. Shell Rotella 15-40 in the truck and the hot rods
__________________
New low boost times 11 psi 10.91 @ 128 MPH 1.76 60ft 6.98 1/8 mile. still only a 306 CID yes its been a lot faster.
uedlose is offline   Reply With Quote
Old 04-11-2009, 01:53 PM   #19
mjr46
mjr46's Avatar
Vehicle: 85 mustang
they don't mean much to you cause your not able to draw a parrallel to the test vs what's going on internally in the engine, but hey that's okay you use what you use and so be it....royal purple has always worked well for me also, that is to keep the garage doors from squeaking
__________________
Old 04-11-2009, 01:58 PM   #20
Speed-Demon
Vehicle: 1992 honda civic si hatchback
^^hahahaha^^
__________________
5.7L PushRod FTW.
Speed-Demon is offline   Reply With Quote
10w40, 1968, 1994, 50, 87, c6, cobra, ford, motor, msd, mustang, oil, synthetic, sythetic, type, walmart, weight
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
