Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-27-2009, 01:09 PM   #11
86HOGT
1986 Ford Mustang
86HOGT's Avatar
Vehicle: 1986, Ford, Mustang GT
I'm running a Taurus Fan and a fan controller from the parts store. Not sure the amp rating on the relay but I put a 30 amp fuse in and it has worked great so far.
__________________
Car Domain
86HOGT is offline   Reply With Quote
Old 04-27-2009, 01:21 PM   #12
KINGKAOS
K thanx! Anyone else?
__________________
1988 Mustang GT 5.0 Convertible Flowmaster cat-back exhaust, 2 owners ago put in a cam(I have no idea which 1) and a fuel cut-off switch.
1982 Yamaha XJ750RJ SECA "In progress Bobber/Chopper Build"
KINGKAOS is offline   Reply With Quote
Old 04-27-2009, 02:07 PM   #13
Bullitt520
Vehicle: 87 Hatch
Im switching to and e-fan as well. I was planning on using a powered switch with an inline fuse and relay. The only thing is the fan is a 2 speed. Does anyone know how i would go about wiring in a hi-lo switch?
__________________
Project: 87 Mustang Hatch Eventual Goal-408 with N2O
Daily: 96 Volvo 850 Turbo I/T/E
Bullitt520 is offline   Reply With Quote
Old 04-27-2009, 02:14 PM   #14
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
Quote:
get a 3 position switch maybe???
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 04-27-2009, 02:33 PM   #15
KINGKAOS
OK so it looks like I'm gonna get a 40amp relay w/ an 40amp in-line fuse... Now I just need to find an 12v key-on source "inside the engine bay".. Anyone?
Thanx
__________________
Old 04-27-2009, 03:28 PM   #16
AdderMk2
MF Attention Whore
AdderMk2's Avatar
www.veryuseful.com
go look at the wiring diagrams... jesus
now I remember why I hate forums so much
__________________
Old 04-27-2009, 04:21 PM   #17
86HOGT
1986 Ford Mustang
86HOGT's Avatar
Haha, right? Mine's hooked up to run all the time.
__________________
Car Domain
Old 04-27-2009, 04:30 PM   #18
mstngsule68
i just got mine on a toggle switch, whenever im in second or lower, i just remember to hit the switch.....
__________________
'87 stang with some goodies on it
'68 stang being restored
"Even one weakpoint, is STILL a weakpoint. Don't make any"
mstngsule68 is offline   Reply With Quote
Old 04-27-2009, 08:19 PM   #19
84conversion50
84conversion50's Avatar
Vehicle: 1990 Mustang GT
Send a message via AIM to 84conversion50 Send a message via MSN to 84conversion50 Send a message via Yahoo to 84conversion50
there is the wire that triggers the starter solenoid for the key on source..... or pull it from the inside of the car.
__________________
1984 5.0! Crane Roller ROckers, 600cfm Edelbrock 4bl carb, R&B cam, Full Stainless Steel Flowmaster Exhaust with long tube Headers(no cats) (sold)
1990 GT 5.0 5spd.
Flowmaster R-spec H pipe and mufflers.
36# injectors
84conversion50 is offline   Reply With Quote
Old 04-28-2009, 12:20 AM   #20
Jon82387
Vehicle: 1990, Ford Mustang GT Conv.
I've got a taurus fan installed in mine, i used a bosch 70 amp relay from NAPA, it was the only place i was able to find it and it took them a bit of searching to find it also. I know the brand is signal-stat but im not sure what the part number was it cost about 20-25 dollars for that 70 amp relay.
Wiring it i used the hi side only on the fan and all you need to do is get a 60-70 amp fuse tapped off your battery then run that to one side of the relay then out of the other side to your fan, then also tap your ground off of the battery straight to the fan #10 awg wire will be fine to use.
Then i purchased this thing from the parts store its like a double tap fuse you can install in your fuse box under the dash with 2 15amp fuses, it seems as there was 1 fuse that was switched with the key and i tapped into that one and ran that to a switch i mounted on my knee panel under the steering wheel. Then from there go to the coil pin of the relay. After that you should just need another ground for the coil side of the relay.
With that setup you will have the fan operated by a switch under the dash.... if you want to get the dcc setup or the parts store probe setup its a little more complicated
__________________
1990 Mustang GT VERT 180k miles
AFR 165's,Holleysystemaxx II, steed #19, 1.7RR, 75mm TB, 76MM MAF, Electric fan, Smog & A/C elimated, MSD Digital 6, 150 Shot
312HP/304TQ Runnin about 11.8 A/F
Jon82387 is offline   Reply With Quote
75, amp, bobber, bosch, buy, fan, ford, install, mark, relay, seca, solenoid
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
