Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-29-2009, 04:28 PM   #1
j-wigg
Vehicle: 88 Mustang GT Conv
Default oil pressure gauge not moving
gauge showing in the normal range 2nd line from the top but has not moved. recently changed intake from stock to 98 explorer upper and lower. oil level is good. gauge worked fine prior to changing intake. use to show at the line below the middle and moved, but now its not going anywhere.
j-wigg is offline   Reply With Quote
Old 04-29-2009, 04:57 PM   #2
timspony
SVT Section Moderator
timspony's Avatar
Vehicle: 03 & 04 SVT Cobra
Need to put a mech. gauge on to check.......maybe the sending unit went bad!
__________________
2003 SVT Cobra, DSG #7248 of 8394, Bassani Catted X, Flowmasters, JLT CAI, 2.76 BF Pulley, AFCO HE, PFab Tanks, SCT Xcal2, Pro 5.0, BF IRS Brace, Nitto 315 DR's...465 rwhp, 456 rwtq - Tuned by Mustang Magic!
2004 SVT Cobra, TR #269 of 1896 RagTop...Not Stock!
timspony is offline   Reply With Quote
Old 04-29-2009, 06:26 PM   #3
j-wigg
where is the sender unit? thats a coincidence
Old 04-29-2009, 06:54 PM   #4
j-wigg
think i found the sender. single white/red wire going right above and next to the oil filter. that was disconnected when the intake was changed. the wire was moved around. maybe check continuity or the wire for damage. that'll wait until tomorrow. any idea on what kind of resistance should be showing for that sender???
Old 04-29-2009, 08:38 PM   #5
84conversion50
84conversion50's Avatar
Vehicle: 1990 Mustang GT
Send a message via AIM to 84conversion50 Send a message via MSN to 84conversion50 Send a message via Yahoo to 84conversion50
ground it out and see if it pegs the gauge.
__________________
1984 5.0! Crane Roller ROckers, 600cfm Edelbrock 4bl carb, R&B cam, Full Stainless Steel Flowmaster Exhaust with long tube Headers(no cats) (sold)
1990 GT 5.0 5spd.
Flowmaster R-spec H pipe and mufflers.
36# injectors
84conversion50 is offline   Reply With Quote
Old 04-29-2009, 10:00 PM   #6
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
did you put it back on???
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is online now   Reply With Quote
Old 04-29-2009, 10:01 PM   #7
mjr46
mjr46's Avatar
Vehicle: 85 mustang
__________________
Old 04-30-2009, 01:09 PM   #8
j-wigg
yes i put it back on. last night i tried to tighten up the plug (maybe didnt have a good connection). no change. i'm gonna go try taking it off, grounding it, and see what happens. does the engine need to be running or can the car be on but not running to get a reading?
Old 04-30-2009, 01:21 PM   #9
j-wigg
disconnected the white/red wire from the sender, turned the car on (not cranked), no change. tried grounding the white/red wire and no change. grounding problem somewhere up the wire to the gauge???
Old 04-30-2009, 07:52 PM   #10
84conversion50
bad gauge or bad ground but if your other gauges work i believe they have the same grounding point.
__________________
1990 GT 5.0 5spd.
36# injectors
50, 98, cobra, ford, gauge, guage, moved, moving, mustang, oil, pressure, reading, wire
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
