New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 05-01-2009, 02:22 AM   #11
domindart
1989 Ford Mustang
domindart's Avatar
Vehicle: 1989, Ford , Mustang
Send a message via AIM to domindart
Quote:
Originally Posted by mjr46 View Post
as mentioned pull the spout and set base at 13 , which where I often set it and it runs well there.
I tried pulling that plug and the car dies. heres a pic-
I shall try setting my timing back a bit a little later, thanks for the advice
__________________
Stock 302 , used to run NOS 125hp dry kit.
Future mods: 373 gears, electric fan, some suspension, minor brake upgrades
http://user.streetfire.net/profile/domindart.htm
everyone in atlanta, join my group, atlanta ga stangs, so we can organise a meet and cruise!
Quote:
Originally Posted by SonicBlueFiveSlow View Post
Don't buy the sixxer, A V6 mustang is not a Mustang at all...it's a...it's a rwd Taurus.
domindart is offline   Reply With Quote
Old 05-01-2009, 06:50 AM   #12
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
^^ your distributor is installed incorrectly... OR your harmonic balancer is spun slightly
__________________
FOR SALE: 1994 Ford Mustang Cobra #1100
http://providence.craigslist.org/cto/1421116930.html
^^^ Just your average 1.5 ton paperweight! ^^
AdderMk2 is offline   Reply With Quote
Old 05-01-2009, 10:35 AM   #13
TrimDrip
TrimDrip's Avatar
Vehicle: 93, ford, mustang lx
Quote:
Originally Posted by AdderMk2 View Post
drop it down to 12 or 13° and I bet it gets faster
I was always told a car needs timing off the line to leave. The further it gets down the track, timing needs to be taken away. Less timing is where you get your MPH.
__________________
93 triple white lx convrt.
5-speed, 327 gear, bone stock block and heads with kenne bell 1.5, 42lb injectors, sct eliminator chip, msd ignition parts and magnaflow 2-1/2" exhaust.
TrimDrip is online now   Reply With Quote
Old 05-01-2009, 04:14 PM   #14
domindart
1989 Ford Mustang
domindart's Avatar
how do you gather that?
I just read from another forum that I have to disconnect the end of that black plug, not the grey one while I check the timing, so I will try that
__________________
Old 05-01-2009, 04:52 PM   #15
TrimDrip
TrimDrip's Avatar
that is the wrong plug, the other is the plug.
I just replaced my balancer. It had slipped. It also wobbled.
Check it running and see if you notice a slight wobble.
Mine was showing 11 degrees when we took it off. It was on 8 when we put the new one on.
Also, you do have the light on the number 1 wire close to the plug?
__________________
Old 05-01-2009, 05:56 PM   #16
domindart
1989 Ford Mustang
domindart's Avatar
I have it on the wire that leads to the #1 I think yes. its the plug that is on the left, if your looking down at the engine, on the left closest to you.
but I took the black plug out, and the car was reading 10* , started up bad and ran slower. put it back in, the car was back at its @ 19* and was making me smile.
I dont beleive my balancer is bad.. it doesnt seem to wobble..
(trimdrip, the grey plug when you unplug it, the car dies. I was told by another forum that it is the black plug next to it that you disconnect)
__________________
Old 05-01-2009, 06:06 PM   #17
TrimDrip
TrimDrip's Avatar
yeah, it is the black one.
__________________
Old 05-02-2009, 02:21 AM   #18
domindart
1989 Ford Mustang
domindart's Avatar
I think I understand how to set timing now. The car runs really good now. Im curious if I were to advance it a couple degrees how it would run!
__________________
Old 05-02-2009, 02:52 AM   #19
302army187
1989 Ford Mustang
302army187's Avatar
Vehicle: 89 mustang lx 'vert
Quote:
Get the car warm. Pull the BLACK plug out, DONT LOSE IT. losen the distibitor just enough to move it, set up your timing gun, check base timing (base timing mean's with the black plug out) if it is set at 10*, turn the distribitor till it is reading 13-15* (you can climb under the car and mark 10*-15* and 20* with a whiteout pen to make it easyer to see) then snug your distribitor back down (check timing again to be sure you dident knock it out of place) put the pigtail back in (black plug) and go run the hell out of the car.
my car run's best with 15-19* without nitrous, but at higher elevation where im at, car's seem to like more timing.
i noticed a big difference in low down power when i bumped my timing up the very first time.
good luck
__________________
302; Cobra T5, 4.10's, ported E7's, Typhoon intake, full bolton's, full exhaust, NX 100-150wet shot
UPR upper/lower control arms, MM full length subframes, Strange Engineering 10way Shocks & Struts
Mods on the way: Ported&O-Ringed Trick Flow heads, TF stage 2 cam, a/c removal, battery relocation
Thanks for the sig' Xeno!
302army187 is offline   Reply With Quote
Old 05-02-2009, 02:53 AM   #20
302army187
1989 Ford Mustang
302army187's Avatar
Quote:
Originally Posted by Bullitt520 View Post
A little off topic but what should timing be at for a 125-150 shot and 93 octane?
i run 13-14* for a 100shot, and 10* for a 150shot. for a 125-150 you can run 10-12*
__________________
1993, 1994, 1995, 87, boost, explorer, ford, gt, jumps, mark, marks, mustang, octane, spout, timing
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
