Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 05-24-2009, 01:01 PM   #1
bigap15
Default Cylinder head bolt question
I had broke cylinder head bolt that we couldnt get out, so we just drill and taped it to a 1/2 inch bolt. The heads have 1/2 inch bolts anyway. Do I torque this one bolt the same as the others or do I torque it to a little higher to the 1/2 inch torque rating.
bigap15 is offline   Reply With Quote
Old 05-24-2009, 01:27 PM   #2
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
time for a new block
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 05-24-2009, 05:20 PM   #3
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
if it was a 302 block you should not of enlarged holes to such, the heads you have are 351 heads and to use on a 302 should of had spacers/bushings installed
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is online now   Reply With Quote
Old 05-24-2009, 06:21 PM   #4
TrimDrip
TrimDrip's Avatar
Vehicle: 93, ford, mustang lx
i bet he has seen it done before and this is the reason being he is asking the question.
TrimDrip is offline   Reply With Quote
Old 05-24-2009, 08:49 PM   #5
NotchAbove
Vehicle: 1993 Mustang Notchback
Well this is a tough question. In retrospect you should not have tapped it out to 1/2", once it broke, machine shop was the only answer. With that said, I would think you should just torque it the same as the others. Best of luck.
NotchAbove is offline   Reply With Quote
Old 05-24-2009, 11:40 PM   #6
bigap15
I have heard of people drilling all of the shorter bolts out to 1/2 inch, I read it helped with nitrous motors to keep head gaskets from blowing. They just said torque them to 1/2 inch bolt specs which are 120 or so. Im not sure. Ive never heard of someone just drilling one of the bolts out. Which is the reason for the question. If i torqued that one bolt more, more pressure be applied right there. So im thinking just torque it the same.
351, al, bolt, head, torque
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
