Code 116 = engine is too cold or coolant temp below 150°F, nothing to worry about.
Regarding the EGR, looks like the valve pintle is getting stuck partially open... causing the higher than normal EVP signal. Remove valve, clean it up or replace it and rerun the self tests. LUK
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________ ACRONYMS:
LUK=Let Us Know, GL=Good Luck, LMK=Let Me Know, JIC=Just In Case, BTSTDTRT=Been There Seen That Done That Repaired That, YCYDYP=Your Car Your Dough Your Prerogative and the classic... DILLIGAS=Do I Look Like I Give A S***
1986 GT-X303-289 heads-1.72 rockers-RG 4+1 Trans.
Quote:
Originally Posted by Joel5.0
Great thoughts will overwhelm a feeble mind.
There is never money to do it right, but there's always money to do it over.
The proof of understanding is the ability to explain it. (H. Torruella)
Thanks Joel, the engine being too cold, causing code 116, is a relief.
Regarding the EGR, is the valve pintle you mentioned inside the EGR? I know it's called an "EGR Valve" so that's what I'm guessing you mean. Edit: Never mind that question. I know where it is now.
And by replace it, you mean the whole EGR?
Is this the valve pintle?
__________________
1965 Wimbledon White Mustang Inline-6 200
1994 Canary Yellow Mustang GT 5.0
PSN: GreatWalrus Videos
Voted as best sig quote of 2008
Yep...... but that one looks like a digital EGR valve used in GM cars.... LOL.... replaced one the day before yesterday in a Buick LeSabre.
Ok, I just tested the vacuum again. This time I got the EGR diaphragm to move and the engine almost died. I retested the CEL codes (just to see if I somehow fixed it) and now it is throwing both code 332 and 334.
334 code is "DPFE or EVP circuit above the closed limit of 0.67 volts."
Does this mean it's the EGR sensor? What should I do next?
edit: Great, now in the KOER test, I'm getting code 116 "ECT out of self test range 0.3 to 3.7 volts." This did not happen when I tested it last night. I got a 1-1-1 pass then.
“If ye love wealth better than liberty, the tranquillity of servitude than the animating contest of freedom, — go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that ye were our countrymen!”
~Samuel Adams
