New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-03-2009, 06:33 PM   #11
matpat
Vehicle: lx 1990
gt-40 heads,headers,2 1/2 exhaust,cam, 3.55. this is my setup.
do 24 pounds are good for me ?
matpat is offline   Reply With Quote
Old 07-03-2009, 07:45 PM   #12
Pony 5.0
Pony 5.0's Avatar
Vehicle: 1990 GT
They would work. How are you set for the intake?
__________________
90 GT
GT40X B-cam, Systemax II, PP 70mm TB, ProM-80@24#, 1.6rr/1.7rr, 2-1/2" BBK LT & o/r X-pipe, Magnaflow catback, Walbro 255, Accufab fpr, UPR subs/uppers/lowers, Battle Boxes, Baer, Eibach, Tokico, Ford truck 3.55 w/ Moser 31's, deep pit to throw money into.
Pony 5.0 is offline   Reply With Quote
Old 07-04-2009, 08:43 AM   #13
matpat
Vehicle: lx 1990
Default egr valve
kn filter,75 mm maf and tb. intake trick flow
my egr valve is pushing on my fuel rail because of my bigger spacer.can i take out my egr valve.will it light on a sensor in my car and if yes how can i bypass this
Old 07-04-2009, 03:09 PM   #14
Pony 5.0
Pony 5.0's Avatar
Vehicle: 1990 GT
24's will work fine for your setup. The EGR can be removed but will cause a check engine light. You will need to put an elimination plate on the EGR spacer and an EGR eliminator on the EGR connector on the wiring harness.
__________________
90 GT
Old 07-04-2009, 08:26 PM   #15
matpat
Vehicle: lx 1990
Default maf
i probably already know your answer but i wanna be sure. everything have been replace to the good place and everything work except when i plug my maf my idle is 1500rpm. So i try with out the maf but the car have not torque.
that s mean that the maf is not calibrated or i have to reprogramm my computer(tune)
Old 07-04-2009, 08:28 PM   #16
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
egr removal will not cause a mil light , when not operational , the ecc iv strategy is to delete the function.
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 07-07-2009, 10:55 PM   #17
matpat
Vehicle: lx 1990
Default problem with my idle
i change my injector to put 24 lbs injector and a 75 mm tb+maf. i had to take out my egr valve. My maf is calibrate for my injector but my idle is going up and down 800 to 1500 rpm.The only way that i stabilize the idle is with the tb screw and he stay at 1000rpm but not for long because he start back going up and down. does the egr removal have a link with my idle problem
Old 07-08-2009, 08:23 AM   #18
kilby94
kilby94's Avatar
Check for vacuum leaks.. And also you might want to try to reset your base idle..
__________________
1991 GT with GT-40P heads, Polished typhoon upper and lower, E-cam, 1.6 rr's, Trick flow valve springs, BBK shorties, 70mm TB and EGR,70mm mass air, 190lph pump, BBK regulator (42psi) MSD wires and coil.
kilby94 is offline   Reply With Quote
Old 07-08-2009, 12:25 PM   #19
matpat
Vehicle: lx 1990
how do i reset my base idle.
Old 07-08-2009, 01:19 PM   #20
kilby94
kilby94's Avatar
Follow the link below:
http://www.moddedmustangs.com/forums...dle-reset.html
__________________
2005, 40, 50, egr, gasket, idle, intake, leak, leaks, lower, maker, manifold, mustang, seal, upper, vacume, valve
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
