New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-02-2009, 08:25 PM   #1
StrongStang50
StrongStang50's Avatar
Vehicle: 2004 SVT COBRA
Default Overheating??
I got my car fully Dyno tuned last Saturday and it ran a little hot. I took it for a ride on Sunday and it was overheating so i ordered a Fluidyne radiator with 2 bottles of water wetter and i plan to run a 70 / 30 mix.
I wanted to make sure it just didnt have an air pocket somewhere so i started it tonight.
I started the car and let it run for a solid 30+ minutes. It wont overheat!!! Heat blows SUPER HOT inside so i ruled out having an airpocket somewhere!!!
The hottest the block got was 209 the fans would kick on over like 185- 190* and run until the car cooled back under that then the fans would kick right back on again...
I let it run so long my eyes were burning!! Do i need to drive it to make it overheat?? I dont get it!!! Should I throw in the new Radiator and the 2 bottles of water wetter with a 70 / 30 mix?
What should it be maxing out at for temp? is 209 - 210 way to much??
Thank you for your help,
Rob
__________________
2004 SVT COBRA Black 495RWHP 530RWTQ
2004 F250 SD CC Diesel Black on Black, lifted.....
StrongStang50 is offline   Reply With Quote
Old 07-02-2009, 09:56 PM   #2
saleenpride1986
saleenpride1986's Avatar
Vehicle: 1990 mustang lx
Send a message via AIM to saleenpride1986
let it get up to operating temp then either while at idle or while moving get the rpm's up a bit. The engine isn't doing much if it's just at idle. when you are in traffic, stop and go throughout town you are constantly accelerating and getting rpms up there which = more heat.
See if you can get it to heat up just by revving it a bit while its at idle and let us know what happens!
__________________
331 with 185AFR's with a ton of goodies! MM complete suspension "Road and Track Box kit".
saleenpride1986 is offline   Reply With Quote
Old 07-02-2009, 10:00 PM   #3
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
I believe low speed fan in an sn-95 comes on 203-208 ish?? and high speed is around 225ish?? so if it follows this pattern all should be normal.
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is online now   Reply With Quote
Old 07-02-2009, 10:11 PM   #4
StrongStang50
So normal operating temp is between 180 and 210??? For some reason I dont remember it getting that hot with the other engine!!
__________________
Old 07-02-2009, 10:12 PM   #5
StrongStang50
Can I wire a switch to the fan to keep it on when im stopped or in traffic or waiting for my next run at the track?? Would it help??
__________________
Old 07-02-2009, 10:14 PM   #6
mjr46
mjr46's Avatar
Vehicle: 85 mustang
you could, I have a thermostatic switch in mine andd an elec water pump and I can run both with engine off and can cool my engine from 210 down to 170 in less than 5 min
__________________
1994, 50, gt, mustang, overheating
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
