So nobody knows how much play should be in the tail shaft bushing? Also i have noticed I have been intermittently getting some pretty bad wheel hop. I don't know if that could be something linked to the vibration problem.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
i have the same damn problem. i have been through two trans, one rebuild, and two driveshafts. i was told i need a clutch. if u fix your problem before i do let me know wat was wrong lol thanks
Alright I made a post a while back and since then I have changed out my warped axle shafts but no difference to the shifter vibration whatsoever. The vibration develops at 90mph and gets progressively worse as the speed increases. The vibration doesn't change with clutch pushed in or in neutral.
I also have new u-joints, transmission cross member, and new trans mount. The tubes on the cross member are not welded but i was told that should be fine. The bolt holes in the bushings on the cross member are bigger in diameter then the bolts the hole is 1/2" whereas the stock bolts are 3/8". Would either of those cause and intense shifter vibration or am i looking at something else? Thanks guys
Are you referring to the bolts on the trans mount or where the crossmember bolts to the unibody. Either way, that can definitely be the source. I will not say it is. But it can. I would NEVER run grossly oversized bolt holes on bolts. That's engineering taboo.
BTW how are your tires? ANY wear will misadjust your alignment and possibly cause this.
__________________
1991 LX 5.0 5Spd
Cobra 4 Wheel Discs/5 Lugs
Saleen SC Wheels w/ 255 Fronts, 275 Rears
Tremec T5
31 Spline Eaton Posi w/ 3.73s
MM Suspension
Stock 5.0 w/ B Cam, Long Tubes, and Pulleys
Dyno Numbers Pending Break In
WTF is a clutch going to fix unless your slipping?
__________________
1991 LX 5.0 5Spd
Tremec T5
MM Suspension
