real 40's sell for $300-$500 bare and stock, a little exhaust porting and get rid of the "bump" and they respond well. my buddy went 11's just like that w/ a stock gt40 tubular intake and 125 shot on all rest stock, just 4.10's and 5-speed
i would never buy an explorer upper... they are no better than stock, actually w/ no head work... no intake will give you more than 5-10 hp
the lower of the explorers w/ the real 40's have a good lower, the "p" explorers have smaller ports on the lower intake.. so it IS NOT the same as all gt40 lowers, all gt40 uppers will bolt to it, but you need to port the he!! out of it
do a search on the guy who ssaid "gt40's for $100 should i buy" he posted a chart in there that has the years for real 40 V "p" explorers w/ casting numbers on it
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
'93 calypso notch 6th stang and counting
nitrous oxide is proof there is a GOD and he wants us to be happy
so if i am getting real gt40 heads is it best to use a real gt40 lower intake and with my stock upper intake is fine? I called this junkyard and they have a 1996 explorer. Will that one have real gt40 heads and the lower intake?
Yes, but the explorer GT40's have a bigger combustion chamber (64cc) and should be milled a little for decent compression...
__________________
1991 GT with GT-40P heads, Polished typhoon upper and lower, E-cam, 1.6 rr's, Trick flow valve springs, BBK shorties, 70mm TB and EGR,70mm mass air, 190lph pump, BBK regulator (42psi) MSD wires and coil.
you cant use your stock upper intake on a GT40 lower
__________________
Siggy removed by Administration.
