Anyone running a Maximum Motorsports K-member? Ive got a team Z in the car right now (havent even taking it off the stands) and I dont like the way it is fitting and its cheaper for me to get a new k-member than it is to buy a cowl hood, 5 lug wheels/tires and 5-lug conversion kit. I just want to know what your thoughts are on the maximum motorsports piece.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
Im running 17x9 wheels and they are touching the lower arms before I even get one full turn of the wheel. I put new prothane motor mounts in also and the motor sits higher in the car. I cant even get the dizzy cap off (due to tower brace) because the motor sits so high.
Since I have those two issues I cant afford to fix both of those so Im going to try a different k-member.
My dad thinks the team z looks weak compared to the MM one also.
Im going to try and sell the team z depending on what they and MM say.
the team z isnt meant to be a road race k-member. if the car is set up for road racing what made you decide to buy a k-member more oriented towards drag racing?
A k member will not solve your wheels hitting control arms issue. For that you need tubular control arms which basically means your going to be buying a coil over kit. I think there's only one company that makes tubular arms compatible with the stock suspension set up. Don't know who it is though. On stock control arms with 17x9s wrapped in 255s, I can get a bit more than 1 full turn of the wheel before hitting. I just use caution when turning until I get a full coil over/k kit this summer.
__________________
1991 LX 5.0 5Spd
Cobra 4 Wheel Discs/5 Lugs
Saleen SC Wheels w/ 255 Fronts, 275 Rears
Tremec T5
31 Spline Eaton Posi w/ 3.73s
MM Suspension
Stock 5.0 w/ B Cam, Long Tubes, and Pulleys
Dyno Numbers Pending Break In
Another thing to take into account is the MM k member offsets the wheel base by a fraction of an inch, they also have control arms that offset the wheel base. When used together the front wheel base is moved an inch and a half forward. You may have tire to wheel well clearance issues, big time. You can get non offset control arms and then the total offset will be somewhere around 1/2 to 3/4 inch. I'm not sure how much the k member moves the wheel base by itself.
__________________
1991 LX 5.0 5Spd
Tremec T5
MM Suspension
