im planning to turbo my '85 5.0 and i was told i will need a blow through carb for the boost. is it possible to use the holly 650 already on my car without modifying it or will i need to modify or even buy a whole new carb?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
I believe they have to be modified. There is a guy in Haleyville, Al that does the blow through carb set-ups. He also drives one himself. The name of the place is Lyle Wrecker service. He gets us pretty good deals on Summitt stuff and is fair with all his customers. He told a friend of mine that he would install and tune a single turbo set-up for 4500. I am not sure if that includes the carb or modifying yours though. You may want to check him out. If you are around Memphis, it shouldn't be no more than 2 hours away.
I'm sure you could use what you have if you keep the boost low. I plan on trying it when I get the stock turbos off a 2jz a buddy of mine is going to purchase just for the hell of it.
__________________ Off building sand castles in the middle east
You need a blow through carb and a pump with higher pressure capability and a boost referenced pressure regulator.
If you don't have a blow through carb you'll get pressure leaks at the throttle shafts and the floats will implode.
__________________
Who cares how much horsepower it has, all that matters is how fast it goes!
13.20's with 2.25-2.30 60's, 40+ year old suspension sucks!
Best trap 107.11mph, we'll see what the new intake/carb setup does.
12.80 at 110.5mph NHRA DA corrected
nope not without a blowthrough carb
__________________
Quote:
Originally Posted by dudeboy
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
