Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-24-2009, 12:27 PM   #1
projectresto83
projectresto83's Avatar
Vehicle: 83 GLX, 93 LX, 98 sixer
Default EFI to carb guys
Those who swapped from EFI to carb, did you get rid of the main engine harness completely or did you keep it?(the one the comp plugged into) And what plugs did you still use if you did???
__________________
Off building sand castles in the middle east
projectresto83 is offline   Reply With Quote
Old 07-24-2009, 01:05 PM   #2
88LXdad
1990 Ford F-150
My Garage
88LXdad's Avatar
Vehicle: 88 Carb'd 302 LX Hactchback
I have a 650 holley on mine and the harness for the fi is gone but the main harness is still used.
88LXdad is offline   Reply With Quote
Old 07-24-2009, 01:12 PM   #3
projectresto83
So are you using your TFI dizzy then to?
__________________
Old 07-24-2009, 02:04 PM   #4
1988TTOP
Vehicle: 1988 GT TTOP
i got trid of all my wiring for the computer and got a dissy for a 85 mustang
__________________
1988 Gt TTOPS 1 1/2 IN LOWERING SPRINGS KYB ADJ SHOCKS MSD COIL FRPP WIRES LONG TUBES O/R X PIPE FLOWMASTERS KING CORBA CLUTCH MGW SHORT THROW SHIFTER F CAM CRAN VALVE SPRINGS ROLLER ROCKERS 650 DP HOLLEY UPPER & LOWER CONTROL ARMS 4.10 GEARS
1988TTOP is offline   Reply With Quote
Old 07-24-2009, 02:08 PM   #5
projectresto83
1988TTOP, what coil did you use?????
__________________
Old 07-24-2009, 02:14 PM   #6
1988TTOP
i used a accel super stock coil
__________________
Old 07-24-2009, 03:09 PM   #7
SonicBlueFiveSlow
1989 Ford Mustang
SonicBlueFiveSlow's Avatar
Vehicle: 1989 Ford Mustang GT
I got rid of the computer and the wiring and I'm using an HEI dizzy.
__________________
Quote:
Originally Posted by cch View Post
bahaha 'magine there was more side bulge then Rosie O'donnel in spandex.
SonicBlueFiveSlow is offline   Reply With Quote
Old 07-25-2009, 10:57 PM   #8
88LXdad
1990 Ford F-150
My Garage
88LXdad's Avatar
I have the TFI dizzy on at the moment until my MSD one comes in.otherwise my coil is an MSD and I have the MsD box too.
Old 07-25-2009, 11:32 PM   #9
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
to all you guys who use the tfi dizzy with a carb set up, don't ask why your car is a turd!!!!!!!!!!!! you can't and shouldn't use such ..why??? you'll only get mech advance..= half of what you should have, you won't have total advance since you don't have a vac advance on it
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is online now   Reply With Quote
Old 07-26-2009, 01:19 AM   #10
projectresto83
I found the wiring diagrams I needed for my ignition so really all I need is to find that one power wire from the ignition to run my box.
Anyone know a good wire to run the ignition box off of on a 91-93 body?????
__________________
302, 50, 89, car, carb, carburated, coil, dizzy, efi, ford, hei, mustang, rid, sn95, texas, tfi
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
