Aftermarket Front Suspension Adjustment Question...
I currently have a QA1 k member installed with QA1 control arms. It has Strange Engineering shocks with a QA1 coil over kit. With this setup and 17x8 cobra wheels I have to let the springs sit higher which give the car a dumb look since the front is higher then the rear. I cant adjust the springs down cause the springs will rub on the tires. What can I do to solve this? Buy new springs with a different rate? Buy smaller diameter springs?
Thanks
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
1990 Ford Mustang Gt Hatchback, bought 9/99. 347 stroker, its got stuff
6/22/09 Tuned by alternative auto, 330hp/360ft lbs
yea just get shorter springs with a higher spring rate. you can always call a company and tell them their issue depending on the type and brand of spring you want. their tech reps are usually pretty good with this kind of stuff.
__________________
I <3 my '89 LX 5.0 + MustangForums.com
