Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-08-2009, 02:45 AM   #1
AYEOH5.0
Unhappy fried piston ring at the track =(
fried a piston ring on the second run at the track, lost 80lbs of compression. so im looking to swap out my pistons for some higher compression since my current ones are low for a blower and im never gonna have the money for a blower. since its a 347 stroker, do my next pistons have to have a certain wrist pin height, or can i just throw in any .030 over pistons? currently it has je 9.5 347 pistons. im looking for around 10.5 compression
__________________
1989 Mustang GT - 347 stroker
AYEOH5.0 is online now   Reply With Quote
Old 08-08-2009, 08:46 PM   #2
tinman
Vehicle: 84 Mustang, 59 Ranchero
Seems to me that a head gasket failed. Good pistons don't just fail.
Anyway, if you are going to replace pistons, you need to use pistons intended for a 347. That means something made for the 3.400 stroke.
I would highly recommend that when you pull the engine apart you take the time to check all the parts very carefully as I think you may not need new pistons.
__________________
GOOD,FAST, CHEAP-----------YOU CAN ONLY GET 2 OUT OF 3!!!!!!!!!!!!!!!!
tinman is offline   Reply With Quote
Old 08-08-2009, 10:24 PM   #3
Tony71502
Tony71502's Avatar
Vehicle: 1991 Ford Mustang
Make sure your head gasket isn't gated.
__________________
1991 LX 5.0 5Spd
Cobra 4 Wheel Discs/5 Lugs
Saleen SC Wheels w/ 255 Fronts, 275 Rears
Tremec T5
31 Spline Eaton Posi w/ 3.73s
MM Suspension
Stock 5.0 w/ B Cam, Long Tubes, and Pulleys
Dyno Numbers Pending Break In
Tony71502 is offline   Reply With Quote
Old 08-09-2009, 09:16 AM   #4
uedlose
1989 Ford Mustang
uedlose's Avatar
Vehicle: 89 mustang
Do you know your piston part#? Like said you will need a piston with the correct pin height and size. Let me know if you are gone to swap them out I have a set for a 347 that I cant use. they are also JE's brand new in the box.
__________________
New low boost times 11 psi 10.91 @ 128 MPH 1.76 60ft 6.98 1/8 mile. still only a 306 CID yes its been a lot faster.
uedlose is offline   Reply With Quote
Old 08-09-2009, 10:01 AM   #5
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
yup you need a piston for a 347, if you fried a piston ring you need to identify the cause so it doesn't happen again.
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 08-16-2009, 07:29 PM   #6
AYEOH5.0
i took my head and gasket to my mechanic and he checked the valves and the gasket and said they are both fine. he reccommended filling up two equally placed cylinders with kerosene to see if one would leak more then the other, i filled #7(the bad one) and #8 both. #7 had leaked all of the kerosene down before #8 had even moved.
__________________
Old 08-16-2009, 07:49 PM   #7
HACKGT350
HACKGT350's Avatar
Send a message via AIM to HACKGT350
well i guess it was the rings. i was gunna suggest doing a cylinder leak down test to make sure before pulling anything apart but it doesnt matter at this point
__________________
Quote:
ORIGINAL: FiveLiterRiceEater
i saw this whore do a sweet trick with about 7 ping pong balls...
Quote:
Originally Posted by simpsonfan13 View Post
you haven't been nominated yet maple sucker..
84 1/2 20th anniversary GT350 5.0 5 speed
99 cherokee xj sport
HACKGT350 is offline   Reply With Quote
Old 08-16-2009, 07:53 PM   #8
AYEOH5.0
Quote:
how can i find the part #? the engine came with these pistons in it and i dont have a box or anything for them.
__________________
Old 08-16-2009, 09:49 PM   #9
mjr46
mjr46's Avatar
Vehicle: 85 mustang
you still need to identify what caused the rings to go out.
__________________
Old 08-17-2009, 12:06 AM   #10
AYEOH5.0
Quote:
i had prior low oil pressure. could that of been a reason?
__________________
1990, 2000, 89, bad, box, ford, fox, fried, gt, identify, mustang, piston, replace, ring, rings
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
