Alright talked to a buddy of mine,and he mentioned something about a motor that hes heard of people building called a long rod 302. I guess these guys are using a chevy rod with a Ford 302/306 piston and making good power....anyone ever heard of this?? And if you have got any info on em?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
88 Hatch Stock Bottom End 302,GT40 Turbo Swirls,Crane Cam, 1.7 rockers,ud pulleys,Holley Blue,16 gallon cell,Edelbrock Performer Intake,650 Holley DP,C4 with TCI goods, Art Carr 3500 Stall,Skinnies,slicks,Best ET 12.43 @ 108 (with 5 speed) Back in 12.90's with C4.
Yea Dude
Racing
302 stroke crank with a 5.400" rod. its NOT a chevy rod. you need to get the correct pistons as the pin is set higher in the piston to offset the longer rod.
the theory is that the piston dwells at TDC and BDC longer.
while i dont know about that, i know that it give you a much more favorable rod/stroke ratio.
__________________
Canary Yellow 1995 Mustang GT
had bolt ons: wasnt fast enough, only beat LT1's.
357W build for about 3 weeks (436rwhp 402rwtq) taken out for my Factory Five '33 Hot Rod
baby boy due 20091203, cars kind of on the back burner (he's gonna help build it).
408W carb'd in the works (block and rotating kit already here).
Reason: typo
5.7" SBC rod with a 1" c/h SBC stroker piston. The piston slows down at TDC and speeds up at BDC, a bit more dwell up top can reduce timing requirements and give a bit of extra detonation resistance, but the biggest advantage is the much shorter compression height of the piston means a much reduced weight. That's the setup I'm running and the pistons I'm running from Mahle are only 383 grams, with a small 112 gram wrist pin. You need to run a 2.100" conrod journal on the crank and machine the big end of the rods to the correct width.
__________________
Who cares how much horsepower it has, all that matters is how fast it goes!
13.20's with 2.25-2.30 60's, 40+ year old suspension sucks!
Best trap 107.11mph, we'll see what the new intake/carb setup does.
12.80 at 110.5mph NHRA DA corrected
