Its all the way down and wont go up.. no noise or anything.. The battery volt gauge moves around when i hit the up button. What can it be? window motor dead?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
When this happened on my Avalanche it ended up being the regulator. I bought a new one that had a new motor already attached and it was a fairly easy fix, but I don't know how difficult it is on a Mustang since we definitely don't have the same years.
Pull the motor out and hook it to a twelve volt battery and see if it turns. If it does then the nylon bushings in the motor are worn out. An easy (and permanent) fix for this is to replace the three bushings with 5/16" - 18 nuts (6 stacked in 3 stacks). Those bushings are a fail safe so no fingers are cut off so dont get your finger caught between the glass when you do this. If that doesnt fix the issue you likely have a bad switch or wiring.
