Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-22-2009, 09:54 PM   #1
kaminski347
Default Idle Surge Problem
I have a 306 with afr 185, b 41, trick flow track heat intake that i dropped in my car. Stock injectors and stock maf for right now. Im just trying to get the car to run strong.
I had a problem with the egr that I fixed but its still running like crap. I can get the car to level off after a while. I thought it was a vacuum leak, but I ran a vac test and its showing -10 to -13.
So its showing vacuum and im pretty sure i have everything sealed. I still have no power brakes.
Could it be a valve timing problem? The car starts and runs ok so i dont think the timings off. Anyone have suggestions?
Edit/Delete Message
kaminski347 is offline   Reply With Quote
Old 08-22-2009, 10:42 PM   #2
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
run a koer test and check for codes
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 08-23-2009, 02:32 PM   #3
kaminski347
Im not throwing any codes that the car is picking up on. Whats a koer test?
Im thinking that I have the wrong vac line hooked up to the egr. I took out the smog pump and the egr used to have a white line that ran to that connection with the smog pump i believe. Its been a while. Where do I run a vac line now that I dont have the smog pump? I tried just using one of the small ones under the intake but thats not working.
Also, should I hook the pcv back up? I plugged that for the time being but i think I should re connect that. Let me know what you guys think.
50, 50l, body, f150, ford, fox, idle, idling, mustang, prob, problem, superchargedmustangidlesurge, surge, surges, surging
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
