Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-30-2009, 12:37 PM   #1
ponyboy88
Vehicle: 1989 LX 5.0 T5
Send a message via AIM to ponyboy88
Default Fiberglass hood install, any help appreciated
Installing a Fiberglass Cobra R hood on my 89 fox and i cant seem to get it to line up correctly and it wont latch... was hoping for some tips on getting this done right...in the meantime im driving around a topless bronco in hurricane season.
I noticed that my new hood doesnt have a set up to use the metel strip that was used to latch/striker the steel hood but instead has it built into the hood...if tht helps at all.
Is there any adjustment in the latch mechanism that is mounted to the car?
Thanks
N/A
__________________
1989 Mustang Lx Sport 25th Ann. Bolt ons. Big Block Swap in Planning.
1979 Ford Bronco, 4 inch lift, 35 a/t 460 + c6 + np205 d44 and 9 inch, debating dana 60/sterling swap.
ponyboy88 is offline   Reply With Quote
Old 08-30-2009, 12:44 PM   #2
LS WHAT
LS WHAT's Avatar
Vehicle: '03 GT
Quote:
you should be able to adjust the catch on the car.
LS WHAT is offline   Reply With Quote
Old 08-30-2009, 01:49 PM   #3
ponyboy88
thanks, any tips on getting the hood lined up straight?
__________________
Old 08-30-2009, 03:08 PM   #4
86 5.0L
86 5.0L's Avatar
Vehicle: '86 Mustang GT
the hinges have adjusments in them, you have to play with those too, which way is it not lining up?
__________________
Car: 1986 Mustang GT Hatchback || 5.0L H.O. || Borg-Warner T5 || 148,000 Miles || 25mpg
Mods: Bfg Traction T/As || Front sway bar || K&N/silencer removed || Hood pins
Times: faster then a speeding Prius
86 5.0L is offline   Reply With Quote
Old 08-30-2009, 03:34 PM   #5
ponyboy88
both laterally and horiuzontally, was hoping there was some age old secret i could be taught... trial and error gets old QUICK.
__________________
Old 08-30-2009, 03:40 PM   #6
Boss_Hotrod
1993 Ford Mustang
Vehicle: 93 Mustang LX
Line the back of the hood up with the cowl. Since it is welded to the body it is a good starting point. Then adjust your fenders to fit the hood. As far as the metal strip goes you dont need it. It is there to help lift the heavy stock hood.
Boss_Hotrod is offline   Reply With Quote
Old 08-30-2009, 04:26 PM   #7
ponyboy88
when you say adjust the fenders you mean adjust the hood according to the fenders should i loosen up the fenders and try and adjust the panels to the hood?
__________________
Old 08-30-2009, 04:48 PM   #8
dv3
Vehicle: 1995 GT, 1992 LX
my latch on my was bent down so mine wouldnt latch so i had to take it off and bend it back up
__________________
'92 LX Convertible --- parting out ..http://mustangforums.com/forum/fox-b...2-lx-vert.html
'95 GT Convertible
dv3 is offline   Reply With Quote
Old 08-30-2009, 04:57 PM   #9
Boss_Hotrod
1993 Ford Mustang
Since the fender and hood move and the cowl does not use the cowl as a starting point. Adjust the hood and fenders to the cowl.
When you adjust a whole car you adjust the doors doors to the body, fenders to door and cowl, hood to cowl and fenders, and bumper to fenders and hood.
You start will what you can not move and what is believed to be correct and go from there.
Old 08-30-2009, 06:25 PM   #10
92hatchLX
Who made the hood?
__________________
I do ultra-sonic reverse flow injector cleaning and rebuilding, pm me if interested
92hatchLX is offline   Reply With Quote
bodies, body, bronco, broncos, cowl, fiberglass, ford, fox, hood, hoods, install, installing, mustang, svo, thread
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
