Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-02-2009, 08:49 PM   #11
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
the cam is useless without changing the heads. and if you keep the stock heads, you MUST change the valvesprings
with the mods you listed, i dont see you getting past 230rwhp
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 09-02-2009, 08:57 PM   #12
Tony71502
Tony71502's Avatar
Vehicle: 1991 Ford Mustang
Well, if you want a relatively stock power band(no head/cam/intake mods)... here you go.....
This is with a BAD o2 sensor AND piston ring blow by AND oil leaks via the valves in cylinder #1 (I'll show u the piston heads/valves if you want).... But, the car also had underdrive pulleys, a timing bump, and a full exhaust(****ty shorties)...
This is what the best dyno pull was...as you can see the power DROPS at 5,000+ rpm on the stock H/C/I...torque drops even earlier...
__________________
1991 LX 5.0 5Spd
Cobra 4 Wheel Discs/5 Lugs
Saleen SC Wheels w/ 255 Fronts, 275 Rears
Tremec T5
31 Spline Eaton Posi w/ 3.73s
MM Suspension
Stock 5.0 w/ B Cam, Long Tubes, and Pulleys
Dyno Numbers Pending Break In
Tony71502 is offline   Reply With Quote
Old 09-02-2009, 09:58 PM   #13
89gtwith3.55s
1989 Ford Mustang
Vehicle: 1989 Ford Mustang GT
i have the 1.6 rr on right now until i can afford a new set of heads.. probly going with edelbrock performer rpm heads maybe the trick flow if i have the money
89gtwith3.55s is offline   Reply With Quote
Old 09-02-2009, 11:01 PM   #14
primetime5.0
Vehicle: 88 GT
Quote:
Originally Posted by 89gtwith3.55s View Post
need another tune though.. im thinking about getting that 4bank chip from american muscle any recommendations?
for the mods you listed? no tuning needed
__________________
R.I.P. Robert H. Western
ported e7's and an e303 cam
primetime5.0 is offline   Reply With Quote
Old 09-02-2009, 11:48 PM   #15
mattdel
mattdel's Avatar
Vehicle: 1986 LX
Send a message via AIM to mattdel
1.6RR was a wasted purchase as the car sits right now. stock rocker ratio is 1.6
you gained nada by doing that.
__________________
mattdel is offline   Reply With Quote
05, 1994, 50, 89, 94, cobra, ford, gt, launch, limit, limiter, mustang, rev, stock, top
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
