Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-05-2009, 09:45 AM   #11
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
Quote:
Originally Posted by mattdel View Post
btw good luck getting $1600 for a used tranny.
read his ad, the 1600 is not just for the tranny
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is online now   Reply With Quote
Old 09-05-2009, 09:45 AM   #12
94StinkinLincoln
94StinkinLincoln's Avatar
Vehicle: 1995 mustang gt
Send a message via Yahoo to 94StinkinLincoln
if your going boosted, i would suggest a min of 42#ers
__________________
95gt, 331, canfield 195's, canfield efi intake; efi spyder elbow, ci cam, 90mm accufab TB, 1 3/4 accufab LT's, 3in accufab h pipe, 3in magnapacks, 4.30's, solid bushing rear upper/lower team z suspension, team z tubular k member and A arms, front coil overs with strange 10 way all the way around. currently aode; going to tko600.
For Sale:
aode,clutches,modified VB,3500 stall,28oz or stock flexplate, any thing needed for swap.
$1600 for trans, converter, and flex plate.
94StinkinLincoln is offline   Reply With Quote
Old 10-04-2009, 12:46 PM   #13
Michael Bachman
Vehicle: 1986 Ford Mustang GT
I've got a 1986 Mustang GT that is all set up for open track events and driver schools. It has a .030 over mallory metal balanced 302, coated TRW forged pistons with reliefs. The heads are semi-ported J302's that I want to upgrade with 2.02 intake valves, lighter springs and get the heads fully ported. I've got a tubular GT40 manifold set-up, 1.72 rockers, 77mm Pro M mass air, 24 lb injectors and the stock 1986 cam (which ramps up faster then the 1987-95 cams do).
Any idea who knows/has experience about porting J302's including unshrouding the valves?
I also want to go with a higher RPM intake set-up and cam and maybe 30 lb injection set up. Any ideas? I've got a 3.73 out back with a T-5 and I'd like to move the power band up to 6500 RPM with a new chip for open track events.
Michael Bachman is offline   Reply With Quote
Old 10-04-2009, 12:49 PM   #14
94StinkinLincoln
victor jr EFI or super victor EFI
__________________
For Sale:
Old 10-04-2009, 03:59 PM   #15
NoGo95GT
1995 Ford Mustang
NoGo95GT's Avatar
Vehicle: 95 Mustang GT
30lb injectors are fine with your set-up. I made 271rwhp/311rwtrq w/30's, had 0 drivability problems and yes I still run them(with an FMU) on my mustang w/Vortech@16psi. I have 42lb injectors, but haven't had the time to throw them on and tune with them
__________________
95 Mustang GT
TrickFlow H/C/I + AODE + Vortech SQ@16psi + Tweecer Tuned by Fritz Kloss
New Dyno #'s: 396rwhp/431rwtq(ran out of fuel)
New ET: 7.57@91 (1.84 60ft)
http://www.youtube.com/watch?v=el5XYPGj4sM&feature
DD: 95 Mustang GTS- 5 spd; 306ci, Magnaflow X, Summit headers, Pypes Cat-back, K&N, MGW shifter
New ET: 9.7@72(2.34 60ft)
NoGo95GT is offline   Reply With Quote
302, arm, bolt, control, ford, gt40, head, heads, j302, j302heads, mustang, pattern, performance, ported, porting, specs, team, upgrade, upper
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
